  • Tang Band 25-2176S 1" Compact Soft Dome Neodymium Tweeter 4 Ohm
CLEARANCE Tang Band 25-2176S 1" Compact Soft Dome Neodymium Tweeter 4 Ohm
Tang Band
Part #264-845
Tang Band
Part #264-845
Model: 25-2176S
Tang Band's 25-2176S 1" soft dome tweeter uses a unique mounting ring design for a clean look without any visible fasteners. With an extremely low Fs of 800 Hz, this is a perfect tweeter for use in 2-way systems with low crossover points.
  • Unique mounting system for an extremely clean installation
  • Integrated grill protects the dome from damage
  • Aluminum housing dissipates heat for high power handling
  • Shorting ring in motor for low distortion at high output
  • Ferrofluid cooling increases power handling and improves damping
The 25-2176S 1" soft dome tweeter from Tang Band combines small size, high power handling, low Fs, and low distortion into a flexible and unique package. To keep this tweeter as small as possible Tang Band uses a solid aluminum threaded housing with a lock ring for mounting which also gives this tweeter a sleek, custom look when installed. The aluminum housing combined with Ferrofluid in the voice coil gap quickly dissipates heat, effectively increasing power handling over most tweeters this small. To keep the resonant frequency low the 25-2176S has a wide surround and heavily damped rear chamber, making it usable with crossovers as low as 1,800 Hz. In addition, the motor system includes a shorting ring to keep distortion as low as possible to produce smooth, non-fatiguing response even at high output levels.
BrandTang Band
Model25-2176S
Part Number264-845
UPC848864035253
Weight0.3
Cone / Dome Diameter1"
Cutout Diameter1.85
Tweeter TypeSoft Dome
Power Handling (RMS)8 Watts
Frequency Response800 to 25,000Hz
Sensitivity89dB 2.83V/1m
Resonant Frequency (Fs)800Hz
DC Resistance (Re)
Voice Coil Inductance (Le)0.003mH
Overall Outside Diameter2.25"
Depth1.45"
    MONSTER DEAL
    OF THE WEEK
    $34.98 EACH
    SAVE 22%
    Lepai LP-168HA 2.1 2x40W Mini Amplifier + 1x68W Sub Output
