  • DC-LE14131 High Power White LED 3W with Heatsink & Driver 3 Pcs.
CLEARANCE DC-LE14131 High Power White LED 3W with Heatsink & Driver 3 Pcs.
Sure Electronics
Part #073-034
Sure Electronics
Part #073-034
Model: DC-LE14131
When a lot of light is needed, count on high power white LEDs.
  • Great for DIY security lights
  • Low power requirement
  • Ultra-wide 160° viewing angle with 80 lumens of output
Create high power lights with the High Power series of LEDs. This LED assembly features 80 lumens of output and a 160° viewing angle. A low power requirement allows you to build an array that sips current, for hours of use. Three LEDs, one heatsink, and a regulated voltage driver are included in this kit for quick prototyping.
Specifications: • Size: 0.79" dia. x 0.31" H (20 x 8 mm) • Lens color: Water clear • Forward current: 700 mA • Forward voltage: 3.6 to 4.0 VDC • Viewing angle: 160° • Color temperature: 6000 to 7000K • Luminous intensity: 80 lumens (15000 mcd @ 160°).
Note: Do not stare directly into LED when in use. Do not apply power to this LED without a proper heatsink in place.
BrandSure Electronics
ModelDC-LE14131
Part Number073-034
UPC844632093517
Weight0.3125
    MONSTER DEAL
    OF THE WEEK
    $14.98 EACH
    SAVE 25%
    Dayton Audio Boost Mini Portable Bluetooth Speaker Black
