  • Selfie Stick with Shutter Button Extendable from 4" to 40"
BUYOUT Selfie Stick with Shutter Button Extendable from 4" to 40"
2 Questions, 20 Answers or
Factory Buyouts
Part #249-180
Factory Buyouts
Part #249-180
Take epic pictures and videos with this buyout selfie stick. Capture button is built into the handle for quick and easy shots.
  • Holds 2-1/4" to 3-1/2" wide smartphones
  • Wired capture button built into the handle for quick shots
  • Extends up to 40" for group, scenery, and inspection shots
  • Collapses down to 9" for easy storage
  • 1/8" wired plug works with iOS & Android smartphones for in handle capture button operation
  • Includes convenient wrist strap
Quantities are limited on this selfie stick with built-in capture button. Now you can take a selfie and not have to worry about setting timers, or reaching out to touch the capture button. With the capture button built into the handle you can now extend the metal shaft out to 40" for those group or scenery shots. You can take videos to inspect underneath vehicles, or extend your arm 40" to take videos or snap shots over crowds.
Android phones must set the volume control to camera mode, or video mode, for the handle capture button to work. You do this by first hitting the camera icon. Then go to camera settings. Then touch the settings icon until you see the option for volume key in the settings list. Most Android phones will already be set to zoom. Touch volume key on the screen and now you can change it from zoom, to camera or record key. Most iOS smart phones are already set up to use the selfie stick's built in capture button. Make sure your smartphone's case does not interfere with the 1/8" cord plugging all the way into your phone.
The selfie stick can expand to hold cellphones up to 3-1/2" wide. It has a rubber tab to help you expand the gripper plus it protects the phone from getting scratched. The bottom of the phone gripper has a foam rubber pad that holds your phone securely without scratching it. The phone holder can also swivel 300 degrees to get the perfect shot and helps reduce the selfie stick's size to 9" for storage.
BrandFactory Buyouts
Part Number249-180
UPC857862003140
Weight0.4
    MONSTER DEAL
    OF THE WEEK
    $45.98 EACH
    SAVE $12
    Dayton Audio KABD-250 2 x 50W All-in-one Amplifier Board with DSP and Bluetooth 5.0 aptX HD
