  • SMSL SU-6 Digital to Analog Converter
NEW SMSL SU-6 Digital to Analog Converter
SMSL
Part #220-110
SMSL
Part #220-110
Model: SU6
The SMSL SU-6 is a high-performance DAC designed to deliver impeccable sound quality and enhance your audio experience. With support for a wide range of high-resolution audio formats, the SU-6 ensures precise and detailed audio reproduction. Its compact design, advanced features, and user-friendly interface make it an ideal addition to any audio setup.
  • Utilizes the ESS ES9038D2M chip, made to deliver only the most high-quality results
  • Low noise switching power supply to keep your music free of electrical humming
  • Audio clock processing circuit will greatly reduce clock jitter
  • Gold plated terminals for increased connectivity
  • Tempered glass display will last forever
  • Remote control so you can switch inputs from the couch
NEW $169.99
MSRP: $242.99
Save $73.00 (30%)
Introducing the SMSL SU-6, a high-performance DAC designed to bring out the finest details in your music. With advanced decoding technology, the SU-6 delivers high-resolution audio that lets you experience your favorite tracks with stunning clarity. Whether you're a dedicated audiophile or just looking to take your setup to the next level, the SU-6's compact design and powerful performance make it an ideal choice.
The SMSL SU-6 is engineered with multiple connectivity options, allowing for easy integration into any audio setup. Its intuitive interface ensures user-friendly operation, while the high-quality DAC guarantees precise sound reproduction. Built with premium components like the ESS ES9038Q2M D/A chip, the SU-6 offers both durability and reliability, making it a valuable addition to any audio system.
  • Input: USB / Optical / Coaxial / Bluetooth
  • Output: RCA
  • Total Harmonic Distortion + Noise (THD+N): 0.0001% (-120dB)
  • Dynamic range: RCA125dB
  • Signal-to-Noise Ratio (SNR): 125dB
  • Output impedance: <10Ω
  • USB transmission: Asynchronization
  • USB compatibility: Windows 7 / 8 / 8.1 / 10, Mac OSX, Linux
  • Bit depth:
    -USB: 1bit, 16 ~ 32bit
    -Optical / Coaxial: 1bit, 16 ~ 24bit
  • Sampling rate:
    -USB:
    -PCM: 44.1 ~ 768kHz
    -DSD: 2.8224 ~ 22.5792MHz
    -Optical / Coaxial:
    -PCM: 44.1 ~ 192kHz
    -DSD: DSD64(DoP)
  • Bluetooth specification: BT 5.0(support SBC, AAC, aptX, aptX HD)
  • Power Consumption: 5W
  • Standby power: <0.5W
  • Size: 5.51" X 1.10" X 4.13" (WxHxD)
  • Weight: 12.35 oz.
    Note: The remote controller uses 2 AAA batteries.
BrandSMSL
ModelSU6
Part Number220-110
Weight0.88
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
