  • Rolls RA63b Rack Mount Distribution Amp 8 Channel Mono/4 Channel Stereo w/Screw Terminals
1 Question or
Rolls
Part #245-1138
Rolls
Part #245-1138
Model: RA63b
1 Question or
Send your signal where you need it, and custom tailor the sound for your next install. Designed for crystal-clear sound and ease of use, the RA63b makes it easy.
  • Mono or stereo operation - mono input to eight mono outputs, or stereo input to four stereo outputs.
  • +20 dB gain switch
  • Screw terminal inputs and outputs
  • Single rack space
Your Price: $239.00
MSRP: $309.00
Save $70.00 (23%)
Order in the next 8 hr 4 min to ship today. Details
The RA63b by Rolls is an eight channel mono, or four channel stereo distribution amplifier designed for the contractor / installer market. The outputs are designed to drive high-level balanced lines in a sound distribution system. The screw terminals on the rear panel are for input and output, and each output may power more than one line. AC power adapter included. Made in the USA.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
Specifications: Frequency response: 10 - 40,000 Hz (±1 dB) • THD: <0.008% • Signal-to-noise ratio: >90 dB • Maximum input level: +22 dBV • Maximum output level: +24 dB • Dimensions: 19" x 1.75" x 6.5" • Weight: 7 lbs.
BrandRolls
ModelRA63b
Part Number245-1138
UPC675889006315
Weight5.2
Mixer TypeAnalog
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
