  • Quest Manufacturing HPS-E14 14 Outlets Horizontal 19" Rack Mount Surge/EMI Power Strip 120V/20A
CLEARANCE Quest Manufacturing HPS-E14 14 Outlets Horizontal 19" Rack Mount Surge/EMI Power Strip 120V/20A
1 Question, 1 Answer or
Quest Manufacturing
Part #125-352
Model: HPS-E14
Extend the AC power and protect your equipment with this 14 outlet, rack mounted, surge protected, EMI filter 16A power strip.
  • Metal housing with built-in mounting brackets for 19" racks
  • 6 ft. SJT 12 AWG x 3C with 5-20P plug for flexibility
  • 1050 joule 3-line surge and EMI protection
  • Eight NEMA 5-20R outlets in the rear and six in the front for convenience
  • 20A circuit breaker reset switch for safety
  • Separate LED indicators for power and surge status
  • UL listed for peace of mind
CLEARANCE $128.98
2In Stock
Protect and extend the AC power to your equipment with this rack mountable, surge protected power strip. Its 6 ft. 12/3 AWG cord with NEMA 5-20P gives you more flexibility to how far you are able to locate your rack from an AC outlet. The eight rear NEMA 5-20R AC outlets keep the rack looking clean and organized, and the front six outlets enable you to quickly access AC for temporary or permanent use. A durable 17-3/8" W x 3-3/4" D x 1-3/4" metal housing surrounds all the outlets and switches, and the built-in EMI filter and 1050 Joule surge protector is constantly there to prevent voltage spikes and interference from damaging your equipment. This metal housing has two 13/16" L x 1-3/4" H built-in brackets that extend out to mount firmly into 19" racks and the two holes on each side line up to standard spaced rack screw holes. The package includes rack screws and extra brackets for additional mounting options.
A red power and green surge protection light keep you informed. A 20A circuit breaker/power switch trips if too much power is drawn from the power strip. The power strip's rating is 16A 125V to meet UL60950-1 standards. A green status light lets you know that the surge protector is functioning properly.
Note: The AC plug on this power strip will only plug into a 20A socket (NEMA 5-20R). Each outlet has a 14A maximum output.
BrandQuest Manufacturing
ModelHPS-E14
Part Number125-352
UPC800118022969
Weight5.55
ColorBlack
Cord Length6'
Number of Outlets14
Special FeaturesRack Mountable-Surge Protection
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
