  • Quam SYSTEM 3 8" Wall Mount Slanted Speaker 5W-25/70V White
Quam
Part #244-3054
Quam
Part #244-3054
Model: SYSTEM 3
The SYSTEM 3/VC by Quam is a complete full range white loudspeaker assembly with an 8" O.D., 5 watt-25/70.7V transformer.
  • 8" O.D. full range speaker
  • 5W-25/70.7V pigtail transformer
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
Your Price: $67.90
MSRP: $72.84
Save $4.94 (7%)
Quantity:Qty: 1-3 $67.90/ea
Quantity:Qty: 4+$67.12/ea
Quam's SYSTEM 3 has a 5 watt-25/70.7V pigtail transformer, and 22 gauge steel baffle and slanted enclosure. Both the baffle and enclosure are finished in a white baked epoxy hybrid. Intended use in an interior environment mounted on a vertical surface, downward firing for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • 25/70.7V transformer: 5, 2.5, 1.25, 0.63, 0.31 watt • Average sensitivity: 92 dB 1W/1m • Power rating: 12 watts RMS • Max. system output: 99 dB SPL, 5W/1m • Magnet type, weight: BeFe ceramic, 4.8 oz. nominal • Frequency response: 65 Hz - 17 kHz • Nominal coverage angle: 100° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" color coded pigtails, pre-cut.
BrandQuam
ModelSYSTEM 3
Part Number244-3054
UPC844632096570
Weight10
ColorWhite
ConfigurationFull-range
Input Rating70V|25V
Woofer Diameter8"
Special FeaturesAngled
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
