  • Quam SYSTEM 19 24" x 24" Lay-In Ceiling Tile Speaker 20W-70V
Quam
Part #244-3172
Quam
Part #244-3172
Model: SYSTEM 19
Quam's SYSTEM 19 is a 24" x 24" lay-in ceiling speaker tile with a 6-1/2" O.D LF, 1" O.D. HF, and 20 watt-70.7V multi-tap transformer.
  • 22" x 24" lay-in speaker tile
  • 20W-70.7V rotary select transformer
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
Your Price: $199.66
MSRP: $233.52
Save $33.86 (14%)
Order in the next 9 hr 11 min to ship today. Details
The QUAM SYSTEM 19 is a complete 2-way loudspeaker assembly with perforated steel baffle, and integral molded fiber enclosure. Finish is a white baked epoxy hybrid. Intended use in an indoor environment, mounted parallel to floor plane in a 24" wide suspended ceiling tile grid for signal tone, voice, and music. The QUAM SYSTEM 19 is UL Listed 1480-(UEAY, UAEY7-Canada) when installed in accordance with supplied installation instructions, requirements of NEC and AHJ. Made in Chicago, USA.
Specifications: • 70.7V transformer: 20, 10, 5, 2.5, 1.25 watt • Average sensitivity: 91 dB 1W/1m • Power rating: 30 watts RMS • Max. system output: 104 dB SPL, 20W/1m • Frequency response: 60 Hz - 20 kHz • Nominal coverage angle: 100° included angle, -6 dB/ 2 kHz, half space.
BrandQuam
ModelSYSTEM 19
Part Number244-3172
UPC844632096877
Weight10.25
Input Rating70V
Mounting StyleDrop-in Tile
Woofer Diameter6.5"
Special FeaturesEnclosed Back-UL1480
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
