  • Quam SYSTEM 16/25RS 12" x 24" Lay-In Ceiling Tile Speaker 4W-25V
CLEARANCE Quam SYSTEM 16/25RS 12" x 24" Lay-In Ceiling Tile Speaker 4W-25V
1 Question, 1 Answer or
Quam
Part #244-3154
Quam
Part #244-3154
Model: SYSTEM 16/25RS
Quam's SYSTEM 16/25RS is a 12" x 24" lay-in coaxial ceiling speaker tile with a 4 watt-25V rotary select transformer.
  • 12" x 24" lay-in speaker tile
  • 4W-25V rotary select transformer
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
The SYSTEM 16/25RS by Quam is a complete loudspeaker assembly with an 8" O.D., full range loudspeaker, 4 watt-25V rotary select transformer, 'MicroPerf' steel baffle, and integrated molded fiber enclosure and trim rail on one 23-3/4" side. Finish is a white baked epoxy hybrid. Intended use in an indoor environment, mounted parallel to floor plane in a 24" wide suspended ceiling tile grid for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • 25V transformer: 4, 2, 1, 0.5, 0.25 watt • Average sensitivity: 95 dB 1W/1m • Power rating: 20 watts RMS • Max. system output: 105 dB 10W/1m • Magnet type: BeFe ceramic, weight: 10 oz. nominal • Frequency response: 65 Hz - 18 kHz • Nominal coverage angle: 100° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" pre-cut.
BrandQuam
ModelSYSTEM 16/25RS
Part Number244-3154
UPC844632097423
Weight5.75
Input Rating25V
Mounting StyleDrop-in Tile
Woofer Diameter8"
Special FeaturesEnclosed Back
    MONSTER DEAL
    OF THE WEEK
    $189.00 EACH
    SAVE 21%
    Dayton Audio SPA250DSP 250W Subwoofer Plate Amplifier with DSP
