  • Quam SOLUTION 1 Complete 8" Ceiling Speaker Package Pair 5W-25/70V
2 Questions, 2 Answers or
Quam
Part #244-3092
Quam
Part #244-3092
Model: SOLUTION 1
Quam's SOLUTION 1 ceiling speaker package consists of two complete loudspeaker assemblies with 8" full-range drivers and 5 watt-25/70.7V pigtail transformers.
  • 8" O.D. full range speaker
  • 5W-25/70.7V pigtail transformer
  • For indoor environments
  • Program material: Paging and background music
  • Made in Chicago, USA
Your Price: $145.90
MSRP: $146.90
Save $1.00 (1%)
Quantity:Qty: 1-3 $145.90/ea
Quantity:Qty: 4+$143.17/ea
The SOLUTION 1 full range loudspeaker by Quam has a 5 watt-25/70.7V pigtail transformer, and 22 gauge steel baffle. A 16 gauge steel enclosure and speaker support bridge is included in package. Baffle finish is a white baked epoxy hybrid. Intended use in an indoor environment, installed in a 24" wide drop-tile ceiling downward firing for paging and background music. Made in Chicago, USA.
Specifications: • 25/70.7V transformer: 5, 2.5, 1.25, 0.63, 0.31 watt • Average sensitivity: 95 dB 1W/1m • Power rating: 20 watts RMS • Max. system output: 120 dB SPL, 5W/1m • Magnet type: weight: BeFe ceramic, 10 oz. nominal • Frequency response: 60 Hz - 17 kHz • Nominal coverage angle: 90° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" color-coded pigtails, tinned and pre-cut.
BrandQuam
ModelSOLUTION 1
Part Number244-3092
UPC844632096655
Unit of MeasurePairs
Weight13.45
Input Rating70V|25V
Mounting StyleIn-ceiling
Woofer Diameter8"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
