Quam C5/BU/W 8" Speaker Screw-through Baffle 5W-25/70V
- 8" framed speaker
- 5W-25/70.7V transformer
- For indoor environments
- Program material: Signal tones, voice, and music
- Made in Chicago, USA
The C5/BU/W by Quam is a complete loudspeaker assembly with an 8" O.D., 12 watt dual-cone full range loudspeaker, 5 watt-25/70.7V transformer, and 22 gauge steel screw mount baffle. Baffle finish is a white baked epoxy hybrid. Intended use is ceiling mounted in an indoor environment downward facing for signal tones, voice, and music. Made in Chicago, USA.
Specifications: • 25/70.7V transformer: 5, 2.5, 1.25, 0.63, 0.31 watt • Baffle: Screw mount • Average sensitivity: 92 dB 1W/1m • Power rating: 12 watts RMS • Calculated output: 99 dB SPL, 5W/1m • Magnet type: weight: BeFe ceramic, 4.8 oz. nominal • Frequency response: 65 Hz - 17 kHz • Nominal coverage angle: 90° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7" long, color-coded tinned wires, pre-cut.
Product Details | |
Brand | Quam |
Model | C5/BU/W |
Part Number | 244-3110 |
UPC | 844632097287 |
Unit of Measure | Each |
Weight | 3.55 |
Product Specifications | |
Input Rating | 70V|25V |
Mounting Style | In-ceiling |
Woofer Diameter | 8" |
