  • QSC CP12 2-Way 12" Active Loudspeaker 1000W
NEW QSC CP12 2-Way 12" Active Loudspeaker 1000W
QSC Audio
Part #245-708
QSC Audio
Part #245-708
Model: CP12
Introducing the QSC CP12 2-Way 12" Active Loudspeaker, an epitome of innovative engineering and compact efficiency. This powerful loudspeaker is part of QSC's esteemed CP Series, designed to deliver superior audio performance with simplicity and versatility.
  • Dynamic Sound Quality: Equipped with a 12" woofer and a 1.4" compression driver, delivering expansive sound with clear highs and deep lows.
  • 1000 Watt Peak Power: Powered by a high-performance Class-D amplifier for consistent and powerful sound output.
  • Versatile Application: Features a simple and intuitive one-touch dial with preset contours for various scenarios, ensuring optimal sound in any environment.
  • Easy to Transport: Lightweight and rugged construction with a comfortable carry handle for easy transportation.
  • Flexible Mounting and Deployment: Can be used as a main PA, floor monitor, or installed via the integrated pole socket and optional yoke mount.
  • Comprehensive Connectivity: Offers a mix of inputs and outputs for microphones and line-level devices, plus a mix output for daisy-chaining additional speakers.
NEW $599.99
MSRP: $749.99
Save $150.00 (20%)
Introducing the QSC CP12 2-Way 12" Active Loudspeaker, an epitome of innovative engineering and compact efficiency. This powerful loudspeaker is part of QSC's esteemed CP Series, designed to deliver superior audio performance with simplicity and versatility. Whether you're amplifying live music, delivering a public address, or enhancing DJ sets, the CP12 stands out with its clarity, robust output, and ease of use. Its compact design does not compromise on sound quality, making it an ideal choice for professionals and enthusiasts who demand reliability and performance in a portable package.
At the core of the CP12's audio excellence is its 12" woofer paired with a 1.4" compression driver, meticulously tuned for clear, dynamic sound reproduction. This setup ensures a full range of sound, from detailed highs to rich, impactful lows, making every performance unforgettable.
The CP12 boasts a 1000 watt peak power Class-D amplifier, providing ample headroom for a variety of settings and applications. This ensures that the loudspeaker delivers consistent, high-quality sound output, even at high volumes, without distortion or loss of clarity.
Featuring QSC's advanced DSP with one-touch dial and preset contours, the CP12 can be easily adjusted to suit any performance scenario, from music playback and live performance to speech and AV media. This versatility allows you to achieve the perfect sound no matter the venue or event.
Designed for musicians, DJs, and event organizers on the move, the CP12 is both lightweight and rugged. Its compact form factor and ergonomic handle make transportation effortless, while its robust construction ensures it can withstand the rigors of the road.
Whether used as a main PA, floor monitor, or mounted for permanent installations, the CP12 adapts to your needs. Its integrated pole socket and the availability of an optional yoke mount provide flexibility in setup and placement, making it suitable for any environment.
Connectivity is key for a seamless setup, and the CP12 excels with multiple input options for microphones and line-level devices. A mix output allows for easy daisy-chaining of additional speakers, ensuring that expanding your sound system is as straightforward as it is effective.
  • Woofer: 12"
  • Compression Driver: 1.4" Titanium
  • Frequency Response (-6 dB): 49 Hz - 20 kHz
  • Nominal Coverage Angle: 75°
  • Maximum Rated SPL: 126 dB
  • Amplifier: Class D, 800 W (LF), 200 W (HF)
  • AC Power Input: 100-240 VAC, 50-60 Hz
  • Enclosure: Polypropylene
  • Attachment Points: M8 threaded insert
  • 516mm × 350mm × 323mm (20.3" × 13.8" × 12.7")
  • Weight: 13.7 kg / 30.3 lb
BrandQSC Audio
ModelCP12
Part Number245-708
UPC684284071323
Weight36.9
Speaker TypeActive / Powered
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
