  • Pyle PDW21250 21" High Power Subwoofer
CLEARANCE Pyle PDW21250 21" High Power Subwoofer
Pyle Audio
Part #292-2526
Pyle Audio
Part #292-2526
Model: PDW21250
The PDW21250 21" subwoofer by Pyle is the ultimate subwoofer with up to 2,000 watts of power handling. Features a die-cast aluminum frame and a 4" aluminum voice coil.
  • 21" high power subwoofer
  • 4" aluminum voice coil
  • Die-cast aluminum frame
BrandPyle Audio
ModelPDW21250
Part Number292-2526
UPC068888888233
Weight51.7
Nominal Diameter21"
Frequency Response24 to 1,700Hz
Sensitivity100dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)22.4Hz
DC Resistance (Re)6.3Ω
Mechanical Q (Qms)2.6
Electromagnetic Q (Qes)0.38
Total Q (Qts)0.33
Compliance Equivalent Volume (Vas)24.85ft³
Maximum Linear Excursion (Xmax)9mm
Surface Area of Cone (Sd)1706cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter21.8"
Baffle Cutout Diameter20.2"
Depth10.2"
Sealed Volume4.79ft³
Sealed F354Hz
Vented Volume10.49ft³
Vented F334Hz
    MONSTER DEAL
    OF THE WEEK
    $19.98 EACH
    SAVE $10
