  • Hi-Performance Powered Dayton Audio Ultimax 8" Mini Subwoofer Kit 300 Watts
CLEARANCE Hi-Performance Powered Dayton Audio Ultimax 8" Mini Subwoofer Kit 300 Watts
Part #300-7330
Part #300-7330
Occupying only 0.35 cubic feet, this Hi-Performance mini 8" subwoofer kit will deliver surprisingly powerful output making it a perfect addition to smaller stereo and home theater systems. With the popular Dayton Audio UM8-22 8" driver and powered by a SPA300-D amplifier, this subwoofer kit has more power and flexibility than you would expect from a system this small.
  • Extremely compact design will fit almost anywhere
  • 300 watt ultra-efficient Class D amplifier offers plenty of headroom
  • Selectable 6dB/oct 30 Hz bass boost for application flexibility
  • Use multiples to help minimize room modes for more even, room-filling low end
  • High excursion Dayton Audio UM8-22 8" driver with 300 watt amplifier provides powerful output capability
  • CNC-cut 3/4" MDF panels for precise fit, easy assembly, and smooth finish
  • Kit includes pre-cut knock down enclosure, subwoofer driver, amplifier, and mounting screws.
Housed in just a 10” cube, the Hi-Performance Dayton Audio Ultimax 8" 300 Watt Mini Subwoofer Kit is the perfect solution for providing high performance bass response without taking up much space. With Dayton Audio's high excursion UM8-22 8" subwoofer driver powered by the extremely versatile SPA300-D 300W plate amplifier you can expect incredibly accurate response with low distortion. The selectable 6 dB bass boost at 30 Hz can help with the lower octaves if you want a little more low-end extension. Thanks to the small size this subwoofer is ideal for using multiples strategically positioned around rooms to minimize room nodes (null and peaks) for more even bass distribution.
The Hi-Performance Ultimax mini subwoofer kit is the last stop for small home theater applications. It will amaze you with incredible dynamics and seemingly endless low-end capabilities.
Simulated Performance Specifications: • Maximum output: 107.2 dB • F3: 48 Hz • F10: 31 Hz • Boosted F10: 24 Hz
Dayton Audio UM8-22 8" Subwoofer Specifications: • Power handling: 300 watts RMS/600 watts max • Le: 1.14 mH • Impedance: 4 ohms • Re: 4.2 ohms • Frequency range: 30 to 800 Hz • Fs: 31.6 Hz • SPL: 84.2 dB 2.83V/1m • Vas 0.75 cu. ft. • Qms: 2.51 • Qes: 0.75 • Qts: 0.58 • Xmax: 16 mm.
Dayton Audio SPA300-D 300W Subwoofer Plate Amplifier Specifications: • Power output: 300 watts RMS into 4 ohms, THD+N <1.5% • Signal to noise ratio: 101 dB (A-weighted) • Low pass adjustment: 40 - 200 Hz • Phase adjustment: Switchable from 0º (normal) to 180º (reverse) • Bass Boost: Selectable, 6 dB/octave at 30 Hz • Power requirements: 110~120/220~240 VAC selectable, 50/60 Hz.
Enclosure Specifications: • Panel thickness: 3/4" • Panel material: Medium Density Fiberboard (MDF) • Finished internal cabinet volume: 0.35 cubic feet • External dimensions: 10" H x 10" W x 10" D • Weight: 23 lbs. • Made in the USA.
Note: Cabinet feet are not included.
Part Number300-7330
UPC848864071954
Weight14.55
Cabinet Dimensions (HxWxD)10" H x 10" W x 10" D
Cabinet OptionsUnfinished/Unassembled
ConfigurationSubwoofer
Speaker TypeActive / Powered
Woofer Diameter8"
MONSTER DEAL
OF THE WEEK
$45.98 EACH
SAVE $12
Dayton Audio KABD-250 2 x 50W All-in-one Amplifier Board with DSP and Bluetooth 5.0 aptX HD
