  • Polk Audio XT10-SUB 10" Powered Subwoofer 50 Watt
CLEARANCE Polk Audio XT10-SUB 10" Powered Subwoofer 50 Watt
Polk Audio
Part #243-618
Polk Audio
Part #243-618
Model: XT10-SUB
Immerse yourself in the richness and depth of audio, as this powerful subwoofer enhances the low-frequency range, bringing out the full impact of explosions, thunderous beats, and rumbling sound effects. The compact design ensures easy integration into your existing setup, without sacrificing the immersive audio quality that adds a new dimension to your entertainment.
  • 10” Dynamically Balanced Woofer provides smooth low-frequency response to 24Hz
  • Timbre-matched with Monitor XT Series speakers for seamless system sound
  • Powerful and efficient 100W peak Class D amplification for maximum bass impact
  • Flexible connections provide compatibility with most home audio systems
CLEARANCE $299.00
4In Stock
Polk Audio Monitor XT10 10" Powered Subwoofer
Take movie, TV, music, and game sound to thrilling new depths
Prepare to be enveloped in the legendary deep, effortless bass that Polk is renowned for, courtesy of the 10" long-throw, high-excursion woofer. With a frequency response reaching as low as 24Hz, this remarkable speaker produces bass that goes beyond mere auditory perception—it resonates deep within your very being. Brace yourself for an immersive experience where you not only hear the bass but feel its reverberations in your bones. The combination of Polk's expertise and the powerful capabilities of the woofer ensures that every low-frequency detail is faithfully reproduced, allowing you to truly connect with the audio and immerse yourself in a visceral, bone-rattling sound experience.
Effortless, High-Resolution Bass
Enjoy Powerful, Clean Sound at Any Volume
Experience consistently pristine sound, no matter your desired volume level, thanks to the robust 100-watt peak, Class D amplifier. This powerful amplifier ensures that the audio remains crystal clear and distortion-free, whether you're dialing the volume down for a quieter ambiance or cranking it up to maximum intensity.
Acoustic Innovations Keep Bass Sound Pure
Experience defined, room-filling low end with the help of a critically braced cabinet featuring a down-firing port. This thoughtfully designed cabinet ensures minimal resonances and sonic interference, allowing the low frequencies to be reproduced with exceptional clarity and precision. By reducing unwanted vibrations and minimizing sonic artifacts, the speaker delivers a clean and well-defined bass response that fills the room with immersive audio.
Customize Bass for Seamless Low-End
Take full control of your bass response with a range of adjustable features. The consistently variable crossover, low-pass filter, polarity switch, and subwoofer volume control empower you to fine-tune the bass to your exact preferences.
Create your dream audio system with the Monitor XT speakers and subwoofers, which are meticulously timbre-matched to deliver a cohesive and harmonious sound signature. This ensures that every component of your system blends seamlessly, producing a balanced and immersive audio experience. You have the flexibility to mix and match different Monitor XT components to suit your preferences and requirements, allowing you to tailor your setup to achieve the perfect soundstage. Whether you're building a stereo system, a surround sound setup, or a custom configuration, the Monitor XT series provides the versatility and performance you need to create your ideal audio system. Experience the joy of crafting a personalized audio setup that delivers exceptional sound quality and coherence across all components.
BrandPolk Audio
ModelXT10-SUB
Part Number243-618
UPC747192139018
Weight27.3
Woofer Diameter10"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
