CLEARANCE Peerless by Tymphany FSL-1225R02-08 Professional 12" Woofer Driver 8 Ohm
Part #264-1412
Part #264-1412
Model: FSL-1225R02-08
The FSL-1225R02-08 8 ohm woofer from Tymphany is an impeccable mix of high efficiency, power handling, and smooth response making it perfect for use in a two way, high output speaker.
- Multi-roll surround and spider have been optimized for reduced distortion
- 2.5" high temperature voice coil and vented pole piece enhance cooling for higher power handling
- Bumped back plate for increased excursion capabilities without bottoming out
- Excellent on and off axis response to 2,500 Hz for natural, space filling sound
We'll send you an email when Peerless by Tymphany FSL-1225R02-08 Professional 12" Woofer Driver 8 Ohm is back in stock or available for preorder.
