  • Peerless by Tymphany 835017 12" Aluminum Cone XXLS Subwoofer
CLEARANCE Peerless by Tymphany 835017 12" Aluminum Cone XXLS Subwoofer
Part #264-1114
Model: XXLS-P835017
This series of state-of-the-art subwoofers continues to enhance Peerless's reputation for delivering the highest quality components for bass.
  • 12.5 mm of linear excursion
  • Extremely durable aluminum cone
  • Cast aluminum frame
  • Flat spider and HD rubber half roll surround
  • Massive stacked magnet
This series of state-of-the-art subwoofers continues to enhance Peerless's reputation for delivering the highest quality components for bass. Called the XXLS—for "Xpanded Extra Long Stroke"—these audio transducers add even more excursion to the Peerless XLS line while completely eliminating distortion. The XXLS line features a strong yet attractive cast frame, reinforced aluminum cone, flat spider, and generous under-spider venting. The magnet system incorporates multiple distortion-canceling fixtures.
BrandPeerless by Tymphany
ModelXXLS-P835017
Part Number264-1114
UPC844632084188
Weight15.4
Nominal Diameter12"
Power Handling (RMS)175 Watts
Power Handling (MAX)350 Watts
Frequency Response19 to 1,000Hz
Sensitivity88.6dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)22Hz
DC Resistance (Re)2.5Ω
Voice Coil Inductance (Le)0.53mH
Mechanical Q (Qms)10.83
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)4.8ft³
Mechanical Compliance of Suspension (Cms)0.42mm/N
BL Product (BL)10.58T·m
Maximum Linear Excursion (Xmax)12.5mm
Surface Area of Cone (Sd)483.1cm²
Cone MaterialAluminum
Overall Outside Diameter12.12"
Baffle Cutout Diameter10.91"
Depth6.38"
# Mounting Holes6
Sealed Volume1.04ft³
Sealed F349Hz
Vented Volume2.64ft³
Vented F329Hz
    MONSTER DEAL
    OF THE WEEK
    $34.98 EACH
    SAVE 22%
    Lepai LP-168HA 2.1 2x40W Mini Amplifier + 1x68W Sub Output
