  • Passive Eminence 8" and Dual Passive Radiator Subwoofer Kit
CLEARANCE Passive Eminence 8" and Dual Passive Radiator Subwoofer Kit
Part #300-7106
Part #300-7106
At only 1 cubic foot, this passive subwoofer kit is a compact powerhouse. With Eminence's 8" high excursion driver and dual 8" high excursion passive radiators, this 12" cube will produce more low end than you would expect from a system this small.
  • Compact design with maximum displacement is perfect for smaller home theater systems
  • CNC-cut 3/4" MDF panels for precise fit, easy assembly, and smooth finish
  • Compatible with any smaller outboard subwoofer amplifier, such as the Dayton Audio SA230
  • Use in pairs to help minimize room modes for more even, room-filling low end
  • Save over $36 off the original price with this bundle
If you need a small subwoofer capable of high output then this passive subwoofer kit is perfect for you. Using the Eminence 8" high excursion subwoofer and 2 of the matching 8" high excursion passive radiators, this tiny system can move a surprising amount of air to produce frequencies from 25 to 150 Hz with authority. Placing this 12" cube behind furniture or tucked away in corners will make it visually disappear in your listening environment. In addition, you can use multiples strategically positioned around your room to minimize room nodes (null and peaks) for more even bass distribution. The dual 4 ohm voice coils offer multiple wiring configurations making this subwoofer compatible with any stand-alone subwoofer amplifier such as the Dayton Audio SA230.
Eminence 8" High Excursion Subwoofer Specifications: • Power handling: 150 watts RMS/300 watts max • Le: 6.1 mH • Impedance: 4 ohms per coil • Re: 6.51 ohms • Frequency range: 25 to 1,500 Hz • Fs: 33 Hz • SPL: 85 dB 1W/1m • Vas 0.52 cu. ft. • Qms: 8.4 • Qes: 0.30 • Qts: 0.29 • Xmax: 11.9 mm • Dimensions: Overall diameter: 8.24", Cutout: 7.13", Depth: 4.75".
Enclosure Specifications: • Panel thickness: 3/4" • Panel material: Medium Density Fiberboard (MDF) • Finished internal cabinet volume: 0.67 cubic feet • External dimensions: 12" H x 12" W x 12" D • Weight: 15.5 lbs. • Made in the U.S.A.
Included Components:
QtyPart NumberDescription
1 290-4008Eminence 8" High Excursion DVC Subwoofer 4 Ohm Per Coil
2 290-4011Eminence 8" High Excursion High Mass Passive Radiator
1 300-7068Denovo Audio Knock-Down MDF 0.67 cu. ft. Subwoofer Speaker Cabinet
1 260-520Sonic Barrier 1/2" Acoustic Sound Damping Foam with PSA 18" x 24"
1 091-1245Dayton Audio BPA-38G HD Binding Post Pair Gold
Note: Screws and speaker wire are not included.
• Frequency response: 25-300 Hz
• Impedance: 2 or 8 ohms
• Sensitivity: 83 dB 1W/1m
• Dimensions: 12" H x 12" W x 12" D
Part Number300-7106
UPC848864036908
Weight30.36
Cabinet Dimensions (HxWxD)12" x 12" x 12
Cabinet OptionsUnfinished/Unassembled
ColorUnfinished
ConfigurationSubwoofer
Input Rating8 ohm
Speaker TypeSubwoofer
Woofer Diameter8"
    MONSTER DEAL
    OF THE WEEK
    $14.98 EACH
    SAVE 25%
    Dayton Audio Boost Mini Portable Bluetooth Speaker Black
