  • PRV Audio 10W1000-NDY-4 10" Neodymium Pro Audio Woofer 4 Ohm
PRV Audio
Part #294-2955
PRV Audio
Part #294-2955
Model: 10W1000-NDY-4
PRV Audio's 10W1000-NDY-4 10" neodymium woofer is carefully crafted to reproduce a natural, smooth sound while remaining dynamic. The 10W1000-NDY-4 is the evolution of our mid-bass loudspeakers, with increased output limits to produce an unparalleled sound reproduction.
  • 3" Inside/outside aluminum voice coil wound on fiberglass former for hi-temp performance
  • 500 watts continuous program power rating makes high acoustical output
  • 36 mm peak-to-peak excursion before damage
  • 97 dB sensitivity, which makes it capable of generating a lot of output
  • Detailed vocal reproduction on a wide frequency band response
Your Price: $199.91
MSRP: $249.89
Save $49.98 (20%)
Order in the next 9 hr 3 min to ship today. Details
8In Stock
The 10W1000-NDY-4 is an extremely efficient 10" woofer from PRV Audio. To stand up to the use and abuse of the professional sound environment, we composed a 3" CCAW voice coil that is wound inside-outside on a fiberglass former with a generous 18 mm winding length for extended xmax and less distortion. Its potent optimized neodymium motor is vented to provide superior cooling. The unique composite cone is built with non-pressed paper for a reduced break-up, delivering a smooth frequency response and a low moving mass, strengthening the efficiency of the speaker.
The large 3" voice coil and the exceptional cooling system implemented into the motor allows for the high 1,000 watts power handling. The high sensitivity rating of 97 dB 1W/1m makes it capable of producing a lot of output!
BrandPRV Audio
Model10W1000-NDY-4
Part Number294-2955
UPC602938022538
Weight10.1
Nominal Diameter10"
Power Handling (RMS)500 Watts
Frequency Response50 to 5,000Hz
Sensitivity97dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)50.19Hz
DC Resistance (Re)
Voice Coil Inductance (Le)0.47mH
Mechanical Q (Qms)8.37
Electromagnetic Q (Qes)0.28
Total Q (Qts)0.27
Compliance Equivalent Volume (Vas)1.64ft³
Mechanical Compliance of Suspension (Cms)0.232mm/N
BL Product (BL)12.03T·m
Diaphragm Mass Inc. Airload (Mms)43.36g
Maximum Linear Excursion (Xmax)6.5mm
Surface Area of Cone (Sd)380cm²
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter10.27"
Baffle Cutout Diameter8.78"
Depth4.49"
Vented Volume1ft³
Vented F352.9Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
