  • NextGen ATH-433 RF Remote Control Extender 433.92 MHz
CLEARANCE NextGen ATH-433 RF Remote Control Extender 433.92 MHz
NextGen
Part #180-828
NextGen
Part #180-828
Model: ATH-433
The NextGen ATH-433 All-Around-the-House remote extender is unlike anything else on the market. It allows you to control all your equipment from anywhere in you home, up to 100 feet*, using your current remote.
  • Control A/V components up to 100+ feet through walls, floors, doors, & windows
  • Total control of A/V components from room-to-room
  • No bulky attachments
  • Convert more than one remote with additional RF transmitters
  • 433.9 MHz frequency
The NextGen ATH-433 All-Around-the-House remote extender is unlike anything else on the market. It allows you to control all your equipment from anywhere in you home, up to 100 feet*, using your current remote. Unlike other bulky remote extenders that attach to the front of a remote, or IR to RF base stations, this one fits in the battery compartment. Small and unobtrusive, you will never know it's there. It doesn't matter where you are in your home; in the living room with the equipment, in the master bedroom, or outside, you have total control. Installation could not be easier, simply remove one of the batteries from your remote and replace it with the RF transmitter and 1.5V mini battery, hook up the receiver base, attach the IR blaster and you are done. You now have a remote that does both IR and RF for a fraction of the cost of other RF systems.
System includes: RF transmitter, (2) mini AAA NiMH rechargeable batteries, AA adapter sleeve, RF base station with an integrated charging station and IR blaster. Two RF kits, with different frequencies, are required for two separate remote controls to be used at two different component locations without interference.
*RF range will very depending upon the layout and construction of your home. Note: The RF signals sent from the transmitter will not directly control SAT receivers or other A/V equipment which receive RF signals. The RF transmitter operates on a different frequency, 433.9MHz, and will only "talk" to the RF base station.
BrandNextGen
ModelATH-433
Part Number180-828
UPC830022004331
Weight0.8
    MONSTER DEAL
    OF THE WEEK
    $14.98 EACH
    SAVE 25%
    Dayton Audio Boost Mini Portable Bluetooth Speaker Black
