  • NTE 60mm 3-Piece Cooling Fan Filter Assembly
CLEARANCE NTE 60mm 3-Piece Cooling Fan Filter Assembly
NTE
Part #250-088
NTE
Part #250-088
Model: 77-FF-60
Keep dust and debris from clogging your cooling fan and shortening the life of your project or components. A two-piece plastic frame enables the filter assembly to be taken apart easily to clean or replace the filter media. This filter assembly fits 60 mm x 60 mm fans.
  • 35PPI filtration rating
  • Fits 60 mm x 60 mm
  • Plastic fan grill keeps fingers from pushing the filter into the fan
This filter is great for keeping dust particles away from your internal electronics and fan blades. Dust on fan blades can build up and put extra strain on the motor and the bearings, causing noise and decreasing the life of the fan. Internal electronics can overheat if dust starts sticking to them or if the fan stops spinning at maximum speed.
BrandNTE
Model77-FF-60
Part Number250-088
UPC768249210276
Weight0.06
Size60
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
