  • Morel TSCW 938 9" Rohacell Cone Woofer 8 Ohm
Morel
Part #297-112
Morel
Part #297-112
Model: TSCW938
For serious speaker builders that demand the world's best, look no further than Morel's Titanium Supreme series TSCW 938 9" Rohacell cone woofer. Featuring a 3" Hexatech voice coil on a titanium bobbin for ultra-quick transient response, a Uniflow chassis for maximum air flow, a copper-sleeved pole piece for reduced inductance this driver, and unyielding carbon fiber sandwich cone, this state of the are driver is ideal for ultra-low distortion designs.
  • Hybrid neodymium-ferrite motor with 3" Hexatech voice coil
  • Copper sleeve pole piece and titanium coil bobbin for low energy storage
  • High 1,000 watt instantaneous power handling is ideal for dynamic response
  • Open Uniflow aluminum diecast chassis for reduced reflections
  • Remarkably stiff carbon fiber/Rohacell cone minimizes unwanted resonances
Your Price: $704.00
MSRP: $874.99
Save $170.99 (20%)
Since 1975, Morel has been on an ever-evolving quest to create the perfect, ultimate loudspeaker. This dedication is apparent in every product they produce: tweeters, midranges, woofers, and finished systems that serve the Hi-Fi, home theater, and car audio markets. Morel systems are today sold in more than 55 countries around the globe. Their products are made with exceptional care; each is assembled by hand and extensively tested, undergoing seven different quality assurance steps, to ensure only the highest standards are met.
The Titanium Supreme woofers from Morel are the latest leap forward in design. Huge 3" Hexatech aluminum voice coils (that use hexagonal shaped wire for high sensitivity and power handling) are wound onto titanium bobbins for amazingly low energy storage, resulting in lightning quick transients for superior attack and decay transients. Qms is also raised, and allows for a wider range of enclosure options. A Hybrid neodymium/ferrite Coppersleeve motor imparts high BL onto the voice coil while the copper-sleeved pole piece further reduces inductance.
The 9" TSCW 938 woofer features a unique, carbon fiber-Rohacell composite cone that offers flat frequency response from 30 Hz to 3,000 Hz on-axis. Its large voice coil allows it to handle 10 ms peak power transients of up to 1,000 watts when used correctly.
Anatomy of the Morel TSCW 938
1)  PFS™ - PROGRESSION FIELD SYMMETRY ENGINEERING - Produces longer linear excursion enabling the spider and surround to reach optimal performance especially at high output levels. Under extreme conditions, the spider and surround progressively act as “shock absorbers” to prevent voice coil displacement and bottoming, and improve voice coil linearity.
2)  CARBON FIBER/ROHACELL CONE - Derived from the drivers of our award winning fat lady speaker system, this cone design is comprised of two exterior carbon fiber skins sandwiching a layer of Rohacell, a high strength, featherweight foam. The combination forms a cone that is light, strong and properly damped for naturally uncolored audio reproduction.
3)  TITANIUM BOBBIN - The bobbin material has influence on the acoustical parameters of the driver, its power handling and the reproduced sound quality. By using titanium bobbin, Morel intended to raise the Mechanical Factor (QMS) in order to enable a wider selection of enclosure types and sizes. As for the sound quality, one is able to discern a distinctively “crisper” sound when compared to an equivalent driver with aluminum bobbin. The rigid characteristic of titanium, along with its other advantages produce a driver that is tonally balanced and accurate, with exceptionally fast transient response.
4)  HEXATECH™ ALUMINIUM VOICE COIL - Made from 100% aluminum wire shaped like a honeycomb, the Hexatech voice coil reduces air gaps in the coil windings, thereby increasing efficiency by up to 20%. Being lightweight, Hexatech  voice coils are largely responsible for the extraordinarily fast transient response Morel drive units are known for.
5)  HYBRID MAGNET TECHNOLOGY - Morel managed to create a symmetric but powerful magnetic field throughout the magnetic gap by using a compact neodymium magnet as the primary magnet, then adding a secondary ferrite magnet on the top plate. This ensures consistent motor force throughout the the full excursion of this driver.
6)  UNIFLOW™ CHASSIS - Uses an open design that is aerodynamically efficient, allowing air and sound waves to flow uniformly and smoothly. Its geometric shape also eliminates interference with the woofer’s moving components, enabling the use of a low-profile spider for greater support and stability.
7)  GOLD PLATED TERMINALS - Well-designed gold plated terminals to ensure high level conductivity between lead wires and speaker cables.
8)  EXTERNAL VOICE COIL (EVC)™ TECHNOLOGY - Morel speakers with EVC technology utilize voice coils that are up to three times larger than those used in conventional loudspeakers. The EVC design moves the magnetic drive system to within the voice coil, eliminating stray magnetic flux by effectively directing all the magnetic energy to the voice coil. The result is an ultra-efficient and powerful design that is highly compact with efficient heat dissipation and reduced cone breakup for lower distortion.
9)  COPPER SLEEVE/RING - Also named shorting ring, a copper sleeve has several clear benefits. First, it reduces impedance rise and increases sensitivity. Also, the voice coil inductance is minimized, which lowers non-linearity during operation. Finally, it improves overall speaker performance across the frequency band by lowering distortion caused by the motor/voice coil system.
BrandMorel
ModelTSCW938
Part Number297-112
UPC848864068572
Weight4.45
Nominal Diameter9"
Bolt Circle Diameter8.42
Power Handling (RMS)180 Watts
Frequency Response30 to 3,000Hz
Sensitivity89dB 2.83V/1m
Voice Coil Diameter2.95"
Resonant Frequency (Fs)29Hz
DC Resistance (Re)6.4Ω
Voice Coil Inductance (Le)0.36mH
Mechanical Q (Qms)6.3
Electromagnetic Q (Qes)0.38
Total Q (Qts)0.36
Compliance Equivalent Volume (Vas)2.895ft³
Mechanical Compliance of Suspension (Cms)0.97mm/N
BL Product (BL)9.85T·m
Diaphragm Mass Inc. Airload (Mms)33g
Surface Area of Cone (Sd)249cm²
Cone MaterialCarbon Fiber
Voice Coil FormerTitanium
Magnet MaterialNeodymium
Overall Outside Diameter8.74"
Baffle Cutout Diameter7.80"
Depth2.8"
Sealed Volume0.75ft³
Sealed F364Hz
Vented Volume1.5ft³
Vented F331.7Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
