  • M.POWER FLTS Flat Lying Trammel Head Set
CLEARANCE M.POWER FLTS Flat Lying Trammel Head Set
M.POWER Tools
Part #365-664
M.POWER Tools
Part #365-664
Model: A-USA/MP/FLTS
Draw circles right, the first time, using M.POWER's FLTS flat lying trammel head set. The FLTS attaches to an aluminum ruler or length of steel to create nearly any size trammel. Use the included blade to cut perfect circles in veneer, or attach to a square for perfect parallel lines!
  • Attach to an aluminum rule or length of steel to mark circles of any size
  • Use the included blade to cut perfect veneer circles
  • Low center-of-gravity design for flat positioning and hands-free stability
  • Die-cast electroplated trammel heads with a carbon steel pivot point
Need to draw a circle? Or rather… Need to draw an accurate circle? One where the finishing point actually meets the starting point? M.POWER's FLTS flat lying trammel head set will guarantee you exactly that. Simply clip the two trammel scribe heads onto any length of steel or aluminum rule from six inches to six feet in length, measure out the required radius between the scribe point and pencil point and lock the second scribe unit. Choose either the included pencil or the hyper fine cutting blade and strike that arc. Attach to a square for perfect parallel lines on almost any surface.
The flat lying, low center-of-gravity design increases accuracy and offers hands-free stability. Versatility is built into the FLTS; you can also use it as a deep range marking gauge or a mortise gauge. For precision marking where a pencil line just isn't fine enough, the FLTS includes a blade post and a bar of replaceable blades allowing you to strike a hyper fine line. Set it up as a trammel compass and accurate circles can be cut out in veneer, light card and paper. Made in England. Two-year warranty.
Includes:
• 6 replaceable blade segments
• 2 die-cast, electroplated trammel heads
• 1 carbon steel pivot point
• 1 angled steel blade post
• 1 Allen key
• 1 pencil
BrandM.POWER Tools
ModelA-USA/MP/FLTS
Part Number365-664
UPC815521000015
Weight0.5
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
