  • Gemini WPX-2000 Modular Line Array Speaker System
NEW Gemini WPX-2000 Modular Line Array Speaker System
Gemini
Part #235-184
Gemini
Part #235-184
Model: WPX-2000
Experience the ultimate in live sound reinforcement with the Gemini WPX-2000 Modular Line Array Speaker System. Designed for versatility and performance, the WPX-2000 brings crystal-clear audio and powerful output to any event.
  • Scalable System Design: Easily expandable to match the size and acoustics of any venue, from small halls to large stadiums.
  • High-Fidelity Sound: Delivers clear, detailed highs and deep, impactful lows for a balanced audio experience.
  • Easy Setup and Configuration: Modular components snap together effortlessly, reducing setup time and complexity.
  • Durable Construction: Built to withstand the rigors of the road with robust materials and protective finishes.
  • Advanced Audio Technology: Incorporates state-of-the-art drivers and waveguide technology for uniform sound dispersion.
NEW $299.95
MSRP: $479.95
Save $180.00 (38%)
Order in the next 2 hr 22 min to ship today. Details
Experience the ultimate in live sound reinforcement with the Gemini WPX-2000 Modular Line Array Speaker System. Designed for versatility and performance, the WPX-2000 brings crystal-clear audio and powerful output to any event. From intimate indoor gatherings to large outdoor concerts, this scalable system adapts to your needs, ensuring every note and word is heard with precision. Its intuitive design allows for quick setup and configuration, making it the perfect choice for event professionals and touring bands.
The WPX-2000's modular design allows for seamless scalability, ensuring optimal sound coverage for any audience size. Whether it's an intimate indoor setting or a sprawling outdoor venue, this system can be customized to deliver precise sound reinforcement that meets the unique demands of each space.
Engineered for clarity and balance, the WPX-2000 produces high-fidelity sound across the entire audio spectrum. From the crispness of high notes to the warmth of lows, every detail is captured and projected with unmatched accuracy, ensuring a captivating listening experience.
In the fast-paced world of live events, time is of the essence. The WPX-2000 addresses this need with a design that emphasizes ease of use and rapid deployment. Modular components lock together quickly and securely, making setup and tear-down faster than ever before, without compromising on stability or performance.
On the road, durability is as important as sound quality. The WPX-2000 is built to last, featuring high-quality materials and a protective finish that resists wear and tear. This resilience ensures that the system not only sounds great but also stands up to the demands of touring and frequent use.
At the heart of the WPX-2000 lies cutting-edge audio technology, including premium drivers and innovative waveguide design. These elements work together to ensure uniform sound dispersion, minimizing hot spots and dead zones. The result is a consistent audio experience for every member of the audience, regardless of their position in the venue.
  • Active/Passive: Active
  • Amplifier Type: Class D
  • LF Driver Size: 8” Subwoofer
  • HF Drivers Size: 6 x 2.75” neodymium drivers
  • Total Power: 1200 Watts Peak (600W RMS)
  • Inputs: 2 x dual ¼” / XLR Switchable Line/MIC Inputs
  • Outputs: XLR Mix Output
  • Media Player: Bluetooth & USB
  • Bluetooth: Bluetooth® Streaming with TWS Link
  • Frequency Response: 50Hz-20KHz
  • Max Peak SPL @ 1 Meter: 116 dB
  • Signal Processing: Reverb Effect and Master EQ (Bass & Treble)
  • Enclosure Material: PP Plastic
  • AC Input Voltage: 110-220V 50~60Hz
  • Power Consumption: 350 Watts
What's in the Box
  • 1 x Array speaker column
  • 2 x Array Spacers
  • Subwoofer Base Station
  • Power Cable
  • Wired Microphone
  • User Manual
BrandGemini
ModelWPX-2000
Part Number235-184
UPC747705008503
Weight40.15
Speaker TypeActive / Powered
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
