  • GRS PZ1188 Piezo Horn Driver Similar to KSN1188A
GRS
Part #292-450
GRS
Part #292-450
Model: PZ1188
Finally, an affordable drop-in replacement for those vintage KSN1188A piezos! GRS piezo tweeters are built using a 22 mm ceramic piezo element, to the original CTS specifications.
  • Perfect replacement for many classic loudspeakers
  • No crossover required - great for simple, economical designs
  • Great for super tweeter applications in DJ/Karaoke systems
  • Equal or superior to products being sold for 8-10 times our price!
  • 22 mm ceramic piezo element that follows original CTS specs
Your Price: $5.79
MSRP: $7.99
Save $2.20 (28%)
Quantity:Qty: 1-3 $5.79/ea
Quantity:Qty: 4+$5.21/ea
The PZ1188 is specifically designed and engineered to be a replacement for the very popular KSN1188A piezo horn drivers from days gone by. Using a 22 mm ceramic piezo element, GRS piezo tweeters follow CTS' original recipe and are far superior to most look-alike piezos.
Standard 1-3/8" 18-TPI threads facilitate use with 1" horns. With a wide frequency range and ample power handling, this is also a prime candidate for new designs, especially if the crossover requirements must be kept to an absolute minimum. This 100 watt driver incorporates advanced protective circuitry which allows it to be used at power levels of up to 400 watts.
Specifications: • Power handling: 400 watts max • Frequency response: 800-20,000 Hz • SPL: 93 dB 1W/1m • Dimensions: Diameter: 3-7/8", Depth: 3".
BrandGRS
ModelPZ1188
Part Number292-450
UPC844632005633
Weight0.4
Diaphragm MaterialPiezo Ceramic
Mounting Type1-3/8"-18 TPI
Power Handling (RMS)100 Watts
MONSTER DEAL
OF THE WEEK
$34.98 EACH
SAVE 22%
Lepai LP-168HA 2.1 2x40W Mini Amplifier + 1x68W Sub Output
