  • Fosi Audio K5 Pro Gaming DAC and Headphone Amplifier
NEW Fosi Audio K5 Pro Gaming DAC and Headphone Amplifier
Fosi Audio
Part #235-262
Fosi Audio
Part #235-262
Model: K5 Pro
The Fosi Audio K5 Pro is a high-fidelity headphone amplifier and digital-to-analog converter (DAC) designed to enhance your listening experience with superior sound quality. Built for gamers, this compact and versatile device ensures that you get the most out of your gaming experience no matter if you're a console or PC gamer.
  • Supports up to 24-bit/192kHz resolution audio for exceptional clarity and detail
  • Supports USB-C, optical, and coaxial inputs for versatile connectivity
  • Line-out and headphone outputs for whether you want to shake the rafter or game into the night without disturbing your roommate
  • Sleek metal housing feels at home in any setup
  • Bass and treble controls to finely tune everything to your taste
  • Compatible with the PS5, Nintendo Switch, PC, and many other gaming systems
  • USB type-C, optical cable, and 3.5mm headphone/mic splitter included
NEW $79.99
Order in the next 5 hr 22 min to ship today. Details
The Fosi Audio K5 Pro combines high-resolution audio support with powerful amplification, making it an excellent choice for players that expect the best. Capable of handling up to 24-bit/192kHz audio, this device delivers exceptional sound clarity and detail, allowing every nuance of your game to be reproduced faithfully. Whether you're using high-impedance headphones or standard models, the K5 Pro provides ample power with its 300mW per channel output, delivering a dynamic and immersive gaming experience.
Connectivity is a breeze with the K5 Pro's multiple input options, including USB, optical, and coaxial inputs, allowing you to connect to a wide range of gaming consoles or your gaming PC. The line-out functionality also enables you to connect the K5 Pro to external amplifiers or speakers for when you're ready to play loud. Housed in a sleek and durable metal casing, the K5 Pro is built to last and is perfect for both stationary and portable use. Its Texas Instruments NE5532 op-amp chip promises a low noise floor further to enhance the listening experience, making the Fosi Audio K5 Pro an indispensable addition to any gamer's collection.
  • Output Power: 1000mw@16Ω, 500mw@32Ω, 300mw@64Ω, 150mw@128Ω, 80mw@300Ω
  • Headphone Impedance: 16Ω - 300Ω
  • Input Type: USB, Optical, Coaxial, 3.5mm
  • Microphone Output Type: 3.5mm Headphone, RCA, USB
  • Sampling Rate: 16bit/44.1KHz to 24bit/96KHz
  • Optical/Coaxial Sampling Rate: 16bit/44.1KHz to 24bit/192KHz
  • Total Harmonic Distortion (THD): <0.003%
  • Signal-to-Noise Ratio (SNR): ≥110dB
  • Device Dimension: 4.4*3.7*1.2 inches (112*95*30mm)
  • Net Weight: 0.55lb (251g)
  • Power Input Interface: USB Type-C
  • Power Supply: 5V
BrandFosi Audio
ModelK5 Pro
Part Number235-262
Weight1
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
