  • FaitalPRO 15PR450 15" Professional Woofer 8 Ohm
FaitalPRO
Part #294-1330
FaitalPRO
Part #294-1330
Model: 15PR450
Choose FaitalPRO's 15" 15PR450 woofer to replace or upgrade the woofer in your speaker cabinet. A flat frequency response to 4,000 Hz and high sensitivity of 98 dB (1W/1m) allows it to match well with nearly any horn driver.
  • 99 dB sensitivity due to high-energy neo motor
  • Durable cast-aluminum frame
  • Ultra-linear frequency response
  • Made in Italy
Your Price: $295.00
5In Stock
With high sensitivity and a ruler-flat frequency response from 35 Hz to 4,000 Hz, FaitalPRO's 15PR450 15" woofer is perfect for replacing and upgrading tired, worn-out woofers in small to large-sized, vented two-way speakers. The 15PR400 is a great choice for live sound and high output home audio speakers.
An eight-spoke, cast-aluminum frame adds structural integrity, while the treated paper cone and accordion cloth surround can withstand years of constant use. The 400 watt RMS power handling rating is made possible by the use of a 3" voice coil on a glass fiber former. Made in Italy.
BrandFaitalPRO
Model15PR450
Part Number294-1330
UPC848864074665
Weight17.85
Nominal Diameter15"
Bolt Circle Diameter14.72
Power Handling (RMS)400 Watts
Power Handling (MAX)800 Watts
Frequency Response35 to 4000Hz
Sensitivity98dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)35Hz
DC Resistance (Re)5.1Ω
Voice Coil Inductance (Le)0.65mH
Mechanical Q (Qms)6.9
Electromagnetic Q (Qes)0.37
Total Q (Qts)0.35
Compliance Equivalent Volume (Vas)8.32ft³
Mechanical Compliance of Suspension (Cms)0.23mm/N
BL Product (BL)16.6T·m
Diaphragm Mass Inc. Airload (Mms)90g
Surface Area of Cone (Sd)857cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerFiberglass
Overall Outside Diameter15.47"
Baffle Cutout Diameter14.02"
Depth6.8"
Sealed Volume84.99ft³
Sealed F31.561Hz
Vented Volume48.74ft³
Vented F34.105Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
