The versatile ELX115 loudspeaker by Electro-Voice is a powerful step up from the ELX112, with an EVS-15K 15" woofer and DH-1K, 1.5" titanium diaphragm compression driver. Features a 15" woofer that delivers extended low-frequency response for bigger sound in larger rooms. This compact, powerful choice with real stage presence is designed for house of worship, pro music, and other applications. Housed in a rugged wood cabinet — pole-mounts or stacks with Live X subwoofers.
Specifications: • Power handling: 400 watts continuous, 1,600 watts peak • Frequency range: 50 Hz – 20 kHz • Sensitivity: 95 dB • SPL: 134 dB max • Frequency response (-3 dB): 75 Hz - 18 kHz • Recommended high-pass frequency: 40 Hz • Crossover frequency: 1.7 kHz • Nominal impedance (passive): 8 ohm • Minimum impedance: 7.4 ohm • Connector type: Dual NL4 • Grill: 18GA steel with black powdercoat • Cabinet material: 9-ply, 15 mm plywood, internally braced, with textured paint • Dimensions: 27.87" H x 17.01" W x 15.04" D (708 x 432 x 382 mm) • Weight net: 50.71 lbs. (23 kg).
