Denon AVR-S770H 7.2 Channel Full 8K Ultra HD AV Receiver with 3D Audio 75 Watts per ChannelPassionate about enjoying music and movies in the comfort of your home? The Denon AVR-S770H is a must-consider choice. Belonging to Denon's esteemed IN-Command series of receivers, it boasts a stellar reputation for delivering top-notch audio and video quality. Packed with convenient home theater features, it promises an immersive and high-fidelity entertainment experience.
Advanced video processing
Denon has outfitted the AVR-S770H with cutting-edge video technology. Among its six HDMI inputs, three are optimized for sharp 4K/120Hz and 8K/60Hz video content, making it ideal for high-quality sources such as a 4K Ultra HD Blu-ray player, Apple TV, or your next-generation gaming system. The remaining three inputs are tailored for 4K/60 video content, ensuring versatile connectivity options.
Denon is all about the “A” in A/V
Easily stream your favorite tunes from your phone or tablet using Bluetooth or Apple AirPlay 2. Access your digital music library via Wi-Fi network connectivity. If you're a vinyl enthusiast, the built-in phono input accommodates your turntable seamlessly. Furthermore, you can indulge in high-resolution audio tracks directly from a USB drive. Plus, for Roon users (subscription required), it effortlessly integrates into your player list for a seamless listening experience.
Expand your system with Built-in HEOS
With HEOS Built-in technology, the AVR-S770H opens the door to your entire music collection, spanning your personal library, internet radio, and popular streaming platforms like Pandora®, Spotify®, and TIDAL.
Moreover, seamlessly incorporate this receiver into your wireless multi-room audio setup. Effortlessly stream music to HEOS wireless speakers and components across various rooms, all controllable individually using the free HEOS app. This intuitive app allows you to manage playback, explore music sources, and choose specific rooms for playback. Whether you prefer uniform music throughout your home or a different soundtrack in each room, the choice is yours.
Power and processing:
• 7-channel amplifier
• 75 watts per channel into 8 ohms (20-20,000 Hz) at 0.08% THD, with 2 channels driven
• Dolby® and DTS® surround sound decoding
• Audyssey speaker calibration and system optimization includes:
Digital and streaming music options:
• built-in Wi-Fi for listening to music from a networked PC, free internet radio, and music services
• HEOS Built-in technology wirelessly connects compatible HEOS components for whole home audio
• Apple AirPlay 2 lets you stream audio using an iPhone® or iPad® and ask Siri to play Apple Music®
• built-in Bluetooth 4.2 for wireless music streaming from smartphones, tablets, and compatible computers
• Bluetooth transmission for sending audio from the receiver to Bluetooth-enabled headphones
• plays high-resolution digital music files via USB storage device or a networked computer (PCM up to 24-bit/192kHz resolution; DSD up to 5.6 MHz)
• Denon's Compressed Audio Restorer improves sound quality of MP3s and other digital music files
• works as a Roon player (requires subscription and Roon Core running on your network)
Multi-room audio/video:
• dual-room/dual-source output
Connections:
• HDMI 2.1 audio/video switching: 6 in, 1 out
• all inputs and outputs support 4K/60Hz video
• HDCP 2.3 technology ensures compatibility with 4K and 8K Ultra HD sources and TVs
• HDR-compatible for extended picture contrast and brightness with compatible 4K TVs and HDR-encoded content
• eARC (enhanced Audio Return Channel) supports the most advanced surround sound formats, including Dolby Atmos and DTS:X, via a single HDMI connection to your TV
• digital audio inputs: 2 optical, 1 coaxial
• 2 RCA line-level stereo analog audio inputs
• MM (moving magnet) phono input for connecting a turntable
• preamp outputs for two powered subwoofers
• front-panel USB port for audio playback from USB storage devices
• rear-panel USB power port
• Ethernet port for network connection
• outputs for 7 speakers (Front L/R, Center, Surround L/R, Surround Back L/R)
• full-sized (1/4") headphone jack on front panel
General features:
• 8K/60Hz and 4K/120Hz video pass-through
• Setup Assistant guides you through the initial connection process and settings
• AM/FM tuner
• remote control
• weight: 19 lbs.
• warranty: 2 years
• MFR # AVRS770HBKE3
