  • Shadow Mounts USAM55 Ultra Slim TV Wall Mount for 23"-55"
Shadow Mounts
Part #182-398
Shadow Mounts
Part #182-398
Model: USAM55
The Shadow Mounts USAM55 features an inconspicuous flat black finish that makes this TV mounting system virtually disappear behind the television display.
  • Tilts down 12 degrees, and rotates up to 90 degrees for optimal viewing
  • Mounts less than 1-1/4" from the wall
  • Extends up to 25" from the wall
  • Dual articulating arms provide fluid motion when adjusting the television
  • Mount TVs 23" to 55" up to 55 lbs.
Your Price: $52.98
MSRP: $56.99
Save $4.01 (7%)
Quantity:Qty: 1-3 $52.98/ea
Quantity:Qty: 4+$50.33/ea
Installation of the Shadow Mounts USAM55 means every seat in the house can be a great one. With tilt adjustments from 0 to -12°, swivel and rotation up to 90°, optimal viewing angles are easily achieved. Manufactured from solid steel, the USAM55 will give you peace of mind knowing your flat screen TV will be held securely in place for years.
The USAM55s most important feature is the low-profile design that holds the monitor less than 1-1/4" from the wall when in the flat position. Fully extend the mount from the wall for 25" of clearance. Dual articulating arms provide fluid motion when adjusting, and prevent the TV from drifting when pulled away from the wall.
The Shadow Mounts USAM55 is ideal for use with 23"-55" televisions or any television with a 400 mm x 400 mm VESA bolt pattern and weight less than 55 lbs.
Note: Consult your TV owner's manual for VESA sizing information.
Specifications: • Mounting bracket 2-1/2" W x 9-3/4" H • Arm dimensions: 1-3/6" H x 3/4" D • TV bracket: 18" W x 17-1/2" H • Tilt adjustment: 0-12° • Minimum mount to wall distance: 1-1/4" • Supported VESA sizes: up to 400 x 400 • Maximum weight capacity: 55 lbs. • Must be stud mounted.
Note: Applicable television size ranges are based on VESA standards and will fit the listed screen sizes. To ensure that this specific TV mount is not exposed behind your TV, identify the length and width of your specific TV and be sure that the mounting bracket, plate, and or articulating arm does not extend beyond your television’s measurements.
BrandShadow Mounts
ModelUSAM55
Part Number182-398
UPC848791001741
Weight13
Mount StyleWall Mount
Mount TypeFull-Motion Articulating
TV Capacity49" to 70"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
