  • Shadow Mounts DCGS Two Component Wall Mount A/V Shelf System
CLEARANCE Shadow Mounts DCGS Two Component Wall Mount A/V Shelf System
Shadow Mounts
Part #182-377
Shadow Mounts
Part #182-377
Model: DCGS
The Shadow Mounts DCGS is a single-column wall mounted AV component system that mounts directly under wall-mounted TVs for a professional look.
  • Strong 8mm tempered-glass shelves and extruded aluminum frame can accommodate up to 40 lbs.
  • Integrated cable management system organizes & routes cables into cable tunnels
  • Column easily attaches to wall for trouble-free installation using included hardware
CLEARANCE $48.23
MSRP: $64.99
Save $16.76 (26%)
18In Stock
The Shadow Mounts DCGS is a single-column wall mount AV component system that mounts directly under wall-mounted TVs for a sleek, finished look. Its sturdy center column sandwiches the shelves for perfect alignment under a wall-mounted TV. The extruded aluminum center column features integrated channels with plenty of space for easy power cable and signal wire routing. 8 mm thick tempered-glass shelves are spaced to accommodate most AV component arrangements. Capable of handling a load of up to 40 lbs. (20 lbs. per shelf)
Shelves measure 17.5" wide by 14" deep and are 10" apart. Overall wall mount height is 21".
BrandShadow Mounts
ModelDCGS
Part Number182-377
UPC844632098857
Weight19.65
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
