  • Dayton Audio PRO Neo-8 Neodymium 1" PEI High Frequency Compression Driver 8 Ohm 1-3/8"-18 TPI
Dayton Audio
Part #275-404
Dayton Audio
Part #275-404
Model: PRO Neo-8
The PRO NEO-8 from Dayton Audio was designed to meet the demands of the market for replacement horn drivers. With a great price-to-performance ratio, you would be hard-pressed to find a better backup to keep on hand!
  • High sensitivity output designed for pro audio duty
  • 1" PEI diaphragm for a smooth response
  • Neodymium magnet for improved output
  • Compact Size to fit in the tightest spaces for smaller boxes
  • Standard 1-3/8 18TPI throat is compatible with many screw on horns
  • 2,500Hz crossover point is perfect for 2-way and 3-way designs
Your Price: $29.98
MSRP: $49.99
Save $20.01 (40%)
Quantity:Qty: 1-3 $29.98/ea
Quantity:Qty: 4+$26.98/ea
Fantastic high-frequency performance, even better value
Key Specs:
  • Power Handling (RMS): 20 Watts
  • Power Handling (MAX): 40 Watts
  • Impedance: 8 Ω
  • Frequency Response: 2500Hz - 20kHz
  • Sensitivity: 105 dB 2.83V/1m
  • Throat Exit Diameter: 1"
Frequency Response & Impedance
The Dayton Audio PRO NEO-8 is a driver that works well with many different types of horns. Due to its rising response, improved efficiency at the crossover point translates to a smooth, non-fatiguing output once installed on a horn. The simple impedance response of the PRO NEO-8 makes crossover design easy!
High Sensitivity
The Dayton Audio PRO NEO-8 has a high sensitivity to keep up with the demands of live audio. Thanks to its neodymium motor, the PRO NEO-8 can keep up when installed in even the most sensitive PA cabinets. When paired with an appropriate horn, the high-frequency detail of the PRO NEO-8 provides a brilliant, airy experience for every audience member in the crowd!
High Value
Dayton Audio created the PRO NEO-8 to provide a compact, reliable replacement option with a standard 1-3/8" threading on the throat, a forgiving sensitivity and response that comfortably integrates with existing designs, all at a great value. These features also put the speaker designer at an advantage, allowing for a large variety of possible combinations when choosing drivers for their own projects!
We've Got Your Back
Learn More
Shop all Dayton Audio Bullet Tweeters
PRO-8
  • Exit Diameter: 1"
  • Frequency Response: 2.6kHz - 20kHz
Shop Now
ST601-4
  • Exit Diameter: 1"
  • Frequency Response: 5.3kHz - 20kHz
Shop Now
ST602-4
  • Exit Diameter: 1"
  • Frequency Response: 6.7kHz - 20kHz
Shop Now
ST603-4
  • Exit Diameter: 1"
  • Frequency Response: 6.9kHz - 20kHz
Shop Now
ModelPRO Neo-8
Part Number275-404
UPC848791008672
Weight0.5
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
