Dayton Audio DPR20-3.0 3 Ohm 20 Watt Precision 1% Audio Grade Resistor
Dayton Audio
Part #007-3
Dayton Audio
Part #007-3
Model: DPR20-3
Designed for use in no compromise crossover designs, Dayton Audio's Precision 20 watt Audio Grade Resistors are ideal for use in your next high end speaker design. The extremely low inductance, non-magnetic construction, tight 1% tolerance, copper end caps, and gold plated copper leads give this high quality 3 ohm resistor the ability to provide reliable and consistent performance without any detrimental effects to the original audio signal.
- Extremely low inductance to avoid any unexpected changes to the audio signal
- Extra long 50 mm leads make these resistors ideal for use in point-to-point circuit designs
- Non-magnetic construction includes nickel-chromium internal wire with copper endcaps and leads
- Internal ceramic tube has great stability and heat dissipation for long life and reliable performance
- Nickel-chromium wiring and non-flammable coating to withstand moisture and corrosion
- Tight 1% tolerance to ensure expected and reliable operation
