DataComm 20-4505-WH Standard Wall Plate with 2 HDMI Connectors and Pigtails White
DataComm Electronics
Part #261-573
Part #261-573
Model: 20-4505-WH
The DataComm 20-4505-WH standard wall plate with 2 HDMI connectors and built-in pigtail cables is the perfect solution to connecting all of your HDMI products behind your walls to give you a clean, organized look.
- Compatible with high speed 1.4 HDMI cords
- Securely attach HDMI cables to the front and back
- Decor insert can be removed for use in multi-gang applications
