  • Celestion TFX0515 5" Coaxial Full-Range Professional Driver
Celestion
Part #294-1974
Celestion
Part #294-1974
Model: TFX0515
With a rigid pressed steel chassis, 1.5” diameter polyimide voice coil, the Celestion TFX0515 provides a very cost-effective addition to the company’s well-established series of coaxial units, for applications including compact, fixed-install sound reinforcement and cinema systems.
  • Exceptional 150W power handling for a 5” driver
  • Silk dome tweeter and integrated waveguide for smooth and linear response
  • 89dB LF sensitivity, 96dB HF sensitivity
  • Large 1.5” LF voice coil for low power compression and high power handling
Your Price: $65.00
MSRP: $97.50
Save $32.50 (33%)
Estimated back in stock 2/28/2025
Alert Me When Available
Incorporating a number of performance improvements over the older TFX0512, including bigger LF and HF voice coils, the new TFX0515 driver also features a larger ferrite motor driving the low frequency element, delivering overall greater power handling.
For HF reproduction, the device features a high sensitivity, 1 inch silk dome tweeter, driven by a highly compact neodymium magnet motor. With neodymium having a stronger magnetic force than ferrite, this permits the high frequency element to be much smaller than would be the case if ferrite were used. The resulting compact size of the HF unit enables it to be positioned inside the LF driver’s voice coil, at the exact point where the acoustic centers of both sources are ‘coincident’. The benefit of this is well-matched directivity and time alignment of the LF and HF signal, delivering maximum signal coherence for a more natural sounding reproduction.
The new TFX driver emphasizes Celestion’s commitment to delivering a wide range of high-quality solutions for sound reinforcement applications that demand a full-range point source solution. They further underscore the company as the world’s number one supplier of branded coaxial transducers.
BrandCelestion
ModelTFX0515
Part Number294-1974
UPC739894644754
Weight4.6
Nominal Diameter5"
Bolt Circle Diameter5.5
Power Handling (RMS)150 Watts
Power Handling (MAX)300 Watts
Frequency Response80 to 20000Hz
Sensitivity89dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)80Hz
DC Resistance (Re)5.77Ω
Voice Coil Inductance (Le)0.363mH
Mechanical Q (Qms)10.966
Electromagnetic Q (Qes)0.665
Total Q (Qts)0.627
Compliance Equivalent Volume (Vas)0.9ft³
Mechanical Compliance of Suspension (Cms)0.291mm/N
BL Product (BL)6.96T·m
Diaphragm Mass Inc. Airload (Mms)9.07g
Maximum Linear Excursion (Xmax)2.25mm
Surface Area of Cone (Sd)78.54cm²
Cone MaterialPaper / Kevlar
Overall Outside Diameter5.4"
Baffle Cutout Diameter4.6"
Depth2.8"
Sealed Volume0.375ft³
Sealed F3116.5Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
