Bluedio H Hurricane Turbine Wireless Bluetooth 4.1 Headphones with Built-in Microphone BlackYou will be amazed by the sounds the Bluedio H Turbine produces. The enormous 57 mm full-range drivers create hard hitting bass while staying true to vocals and instrumentation. Extra padding on the ear cups and headband make these headphones very comfortable, so wearing them for hours at a time will never be a problem.
Convenience is what separates these headphones from standard ones. Connect with Bluetooth so you don't have to worry about tangled cords. If you do want a wired connection the H Turbine's have a 3.5 mm jack built-in so you can use them in a traditional fashion. Answer calls and talk freely with the built-in microphone. Simply press the multi-function button to answer calls, or hold it for 2 seconds to reject that call. Volume, EQ, and track selection are also controlled from the right ear cup, so you can keep your phone in your pocket or purse. Headphones like these usually cost several hundred dollars, but the Bluedio H Turbine will deliver great sound and features for a fraction of that price.
Note: To change the language of these headphones, simply press and hold the volume down button, then press the power button to toggle through the available languages.
Specification: • Drivers: 57 mm • Frequency response: 20-20,000 Hz • Bluetooth version: 4.1 • Bluetooth profiles: A2DP, AVRCP, HFP, HSP • RF frequency range: 2.4-2.48 GHz • Operating distance: 30 ft. • Music playtime: 40 hrs. • Talk time: 45 hrs. • Standby time: 1,625 hrs. • Charging time: 2 hrs.
