  • Behringer XR12 X Air 12-Input Rack Mount Digital iPad / Tablet Mixer with WiFi & USB
CLEARANCE Behringer XR12 X Air 12-Input Rack Mount Digital iPad / Tablet Mixer with WiFi & USB
Behringer
Part #248-6876
Behringer
Part #248-6876
Model: XR12
Behringer rewrote the live sound playbook with the X32 digital mixer. The X Air series of tablet-controlled mixers is going to change the game once again. Much of what made the X32 so massively popular is present in the X Air series, plus on-board Wi-Fi and more, in a much smaller format you control via your iPad, laptop, and/or Android devices.
  • iPad / Android tablet-controlled 12-input digital mixer for studio and live applications
  • 4 award-winning Midas-designed, fully programmable mic preamps for audiophile sound quality
  • Built-in tri-mode Wi-Fi router for wireless operation - no need for external routers
  • Award-winning X32 effects rack featuring 4 stereo FX slots
  • Two aux and main LR buses with inserts, full dynamics processing and 6-band parametric or 31-band graphic EQ
  • 100-band Real Time Analyzer (RTA) for all channel and bus EQs
  • 3-year warranty
The revolutionary XR12 is a powerhouse 12 input portable mixer housed in an sturdy rack-mountable stage box, designed for use with iPad and Android tablets or PC/Mac computers. It is ideally suited for both live and studio applications, thanks to its 4 award-winning Midas-designed mic preamps, 8 line inputs, convenient integrated Wi-Fi module for wireless control, and a handy USB port for L/R stereo recording.
The freedom to move around and manipulate all parameters of your mix with the free iOS, Android and computer apps lets you dial in the perfect sound from anywhere in the venue, or the tracking room. Advanced engineering and meticulous design deliver stellar sonic performance at an extremely affordable price. Behringer is changing the game -- again!
Legendary Sound Quality by Midas
Ever since its formation in the 1970s, Midas has had a long history of innovation and leadership in the world of audio mixing consoles. Employed by the most famous touring acts and installations worldwide, legendary Midas consoles such as the XL4 and Heritage H3000 quickly became industry standards.
Behringer is proud to incorporate Midas-designed mic preamps in the X Air mixers, for the ultimate in high-quality audio reproduction in both live and studio environments.
Wi-Fi or Hard-Wired - No Router Required
Designed for the ultimate in mobility, the XR12 comes with an integrated Wi-Fi module for direct control of your mixer’s functions, without the need to setup and configure an external router. The XR12 gives you the freedom to focus on your mix, while allowing you to move about the venue to experience what every part of the audience is hearing. Plus you can adjust live monitor wedges from the artist’s perspective – or better yet, let them mix their own IEMs and floor monitors via their own tablets or smartphones.
Access Point is the easiest way to connect up to 4 clients directly and concurrently (i.e., iPad, Android smartphone/tablet or laptop). This mode should have your remote control up and running in less than a minute.
Wi-Fi Client allows you to add your mixer to the existing wireless network where the controlling apps and devices are connected.
• Alternately, wired connections can be made directly to your PC, to a local area network (LAN), or when connecting to a dedicated Wi-Fi router, e.g., for extended range or 5 GHz applications.
Did Someone Say "Recording"
The front panel USB type-A connector makes the XR12 not only an amazingly powerful digital mixing solution, but also allows recording your live stereo tracks directly to attached USB flash media or hard drives. Dial in the perfect live mix with effects and zero-latency, while sending a dedicated stereo mix to your thumb drive for recording, or play background music on a break. Whether you’re making rock history in the studio, or you want to capture intimate live performances – it’s never been easier to record stunning tracks with exceptional clarity.
Effective Effects - Minus The Rack
Equipped with the very same FX engines as the now legendary X32 Digital Mixing Console, the X Air's onboard Virtual FX Rack provides access to four true-stereo (8 mono), multi-effects processors including delay, chorus, dynamics, and the XR12 can run production-quality, true-stereo reverbs concurrently with 31-band EQ on the main and aux buses, all without the need for any additional hardware.
You can select any combination of high-end simulations of legendary studio effects, such as the Lexicon 480L and PCM70, as well as the EMT250 and Quantec QRS reverbs. Onboard processing means your computer doesn’t have to do the heavy lifting during a mixing session with DAW plugins, as the XR12 has a whole studio of FX under the hood.
Custom-designed and physically modeled after some of the most iconic and sought-after processors, all effects run inside the low-latency environment of the XR12 mix engine, ensuring flawless performance, flexible routing and the end of insert and patch cable faults -- forever!
Analyze and Conquer
The XR12 includes a high-resolution 100-band real-time analyzer (RTA), with full Bar and Spectrograph views. This high-resolution RTA displays the audio energy distribution in 100 frequency bands over time, capturing a sonogram window of a full 10 seconds.
Switch between the large RTA view, displaying any available signal in full screen resolution, or the combined RTA view shown above each of the channel and bus EQ curves, and instantly see the results of your filtering choices. Additionally, the RTA can be displayed on top of the 31-band graphic EQs in the Main LR or Aux buses. Monitoring and controlling frequencies has never been easier!
Process Every Channel - Like A Boss
The XR12 allows you to achieve the same incredible level of EQ finesse as the award-winning X32 thanks to its 100-band Real Time Analyzer, which is built into every input channel and bus EQ. Visual feedback built into the control app allows you to see and make fast, surgical adjustments to frequencies in need of a boost or a cut. You’ll wonder how you ever EQ’d without it!
Every input channel also features Low-Cut, 4-band fully parametric EQ and the same Gate and Compressor dynamics suite found in the X32, with one very special addition: you can choose either Expert or Simple functionality. In Expert mode, you can drill down and get your hands on every nuance of your dynamics. Or, if you’re more of the ‘plug and play’ type, Simple mode lets you either select from one of our 4 carefully-optimized presets or load your own channel templates. Add to this 40-bit, floating-point DSP and you’ll experience virtually unlimited dynamic range with no internal overload and near-zero overall latency.
In addition to the Main L/R bus for front of house, 6 Aux buses are provided for dialing in the perfect monitor mixes, or creating a dedicated mix for your USB stereo recording – complete with inserts, dynamics, and either a 6-band parametric EQ or 31-band graphic EQ. And if all these outstanding EQ options put a smile on your face, you’ll love it even more when we tell you that 100-band RTAs are available for these, too!
MIDI For Fun And Profit
The physical MIDI I/O port on the XR12 mixer can also be used for connecting external MIDI controllers, such as Behringer X-Touch or B-Control products, for dynamically controlling channel level, muting and panorama adjustments during your performance. And since the full-featured XR12 also supports the Mackie Control protocol, you can easily apply comprehensive remote editing and parameter adjustments via any compatible MIDI devices.
With Apps and Software for ALL!
Since one size doesn’t always fit all, Behringer went the extra mile and provided apps for all the most popular devices and operating systems. They engaged dedicated (and highly caffeinated) development teams to produce iOS, Android, PC/Mac and even Linux based applications for the XR12 mixer. When you download an X Air app for your device, you can rest assured that you will get the fully optimized experience just as Behringer intended.
Compose. Record. Mix. Share.
Tracktion is one of the world’s fastest and easiest Digital Audio Workstations (DAW) for composing, recording, editing, mixing and sharing your music with the world. Featuring a single-screen interface, and pushing the envelope in design elegance, Tracktion brings together outstanding pro DAW features, such as dynamic automation, unlimited track count, MIDI recording and support for VST and AU plug-ins. This powerful music production software gives you all the tools of an entire professional-grade recording studio. Learning a DAW has never been easier, thanks to their vast and readily available library of resources.
As a way of saying "Thank You," when you register your XR12 mixer at behringer.com, you'll get a complimentary download code for the full version of Tracktion 4, or for a 50% discount on Tracktion 5. Recording and editing couldn’t be easier.
BrandBehringer
ModelXR12
Part Number248-6876
UPC748252150844
Weight7.25
Mixer TypeDigital
XLR Mic Inputs< 6
Special FeaturesDigital Effects-USB Connectivity
MONSTER DEAL
OF THE WEEK
$45.98 EACH
SAVE $12
Dayton Audio KABD-250 2 x 50W All-in-one Amplifier Board with DSP and Bluetooth 5.0 aptX HD
