  • Avantree Saturn Pro Wireless Bluetooth Receiver and Transmitter aptX Low Latency
CLEARANCE Avantree Saturn Pro Wireless Bluetooth Receiver and Transmitter aptX Low Latency
Avantree
Part #320-342
Avantree
Part #320-342
Model: Saturn Pro
The unique Avantree Saturn Pro encompasses a Bluetooth transmitter and receiver in a single unit and the Low Latency aptX codec makes it perfect for use with your television. Using Bluetooth headphones, you can now watch TV without disturbing others and the Low Latency codec makes sure the dialogue is never out of sync with the image.
  • Bluetooth transmitter and receiver in one unit for maximum versatility
  • 32ms low latency aptX means your TVs dialogue is never out of sync with the image
  • Powerful battery life: 15 hours transmitting or 10 hours receiving
  • Easily connects to TVs, amps, and headphones with its 3.5 mm audio jack
  • Includes several adapter cables to make hook up simple
Cast off traditional cables and go wireless with the Avantree Saturn Pro. This versatile Bluetooth adapter both transmits and receives using the Low Latency aptX codec. You can upgrade legacy audio equipment, transmit your TV's audio signal to Bluetooth headphones, or add Bluetooth to any car stereo with a 3.5 mm jack. Or, use them in pairs; one as a transmitter and one as a receiver to create unlimited wireless solutions. You can also turn any pair of standard headphones into Bluetooth headphones by simply plugging them into the Saturn Pro. The Low Latency codec transmits and receives audio within 32ms which is unperceivable to the human ear , ensuring the dialogue and TV image never go out of sync.
The Saturn Pro comes equipped with a powerful battery that, on a full charge, will transmit up to 15 hours or receive up to 10 hours. You can also operate the Pro while plugged into any 5V USB source thanks to the included cable. Also included are a straight 3.5 mm male to male adapter, a 3.5 mm male to male cable, and a RCA stereo male to 3.5 mm female cable. Everything is included to hook up the Saturn Pro right out of the box.
Specifications: • Bluetooth version: 3.0 • Bluetooth profiles: A2DP, AVRCP • Audio codec: aptX-LL, aptX, SBC, AAC • Operating range: 33 ft. line of sight • Battery life: 15 hours transmitting, 10 hours receiving, 150 hours standby • Charging time: 2-3 hours • Charging input voltage: 5 VDC • Battery: 270mAh rechargeable Li-Ion • Dimensions: 2" W x 1-1/2" H x 1/2" D.
BrandAvantree
ModelSaturn Pro
Part Number320-342
Weight0.32
    MONSTER DEAL
    OF THE WEEK
    $29.98 EACH
    SAVE 25%
    Talent SB16-32 Stage Boss 32.5 ft. 16/3 Multi-Outlet Commercial Grade Extension Cord with 7 AC Sockets
