  • Audio-Technica PRO 45W Hanging Condenser Microphone White
CLEARANCE Audio-Technica PRO 45W Hanging Condenser Microphone White
1 Question, 2 Answers or
Audio-Technica
Part #242-4864
Audio-Technica
Part #242-4864
Model: PRO 45W
With robust construction and unobtrusive appearance, the PRO 45W offers versatile sound-reinforcement solutions for speech, theater, orchestra and choir sound reinforcement and recording. The microphones' high-SPL handling is perfect for suspension over choirs and orchestras.
  • Hi-SPL handling is ideal for suspension over choirs and orchestras
  • Wide-range condenser element with low-mass diaphragm for superior performance
  • Self-contained electronics eliminate need for external power modules
  • Flat, smooth frequency response
  • 25 ft. (7.6 m) cable permanently attached between microphone and XLRM-type connector
CLEARANCE $79.00
MSRP: $99.00
Save $20.00 (20%)
1In Stock
With robust construction and unobtrusive appearance, the PRO 45W offers versatile sound-reinforcement solutions for speech, theater, orchestra and choir sound reinforcement and recording. The microphones' high-SPL handling is perfect for suspension over choirs and orchestras. White in color. Included furnished accessories: AT8146 windscreen and a steel hanger.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 70-16,000 Hz • Open circuit sensitivity: -37 dB (14.1 mV) re 1V at 1 Pa • Impedance: 100 ohms • Maximum input sound level: 134 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 106 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 66 dB, 1 kHz at 1 Pa • Phantom power requirements: 9-52V DC, 2 mA typical • Dimensions: 2.24" (56.9 mm) long, 0.47" (12.0 mm) head diameter • Output connector: 3-pin XLRM-type on cable • Cable: 25 ft. (7.6 m) long, permanently attached.
BrandAudio-Technica
ModelPRO 45W
Part Number242-4864
Weight0.4
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
