  • Audio-Technica BP40 Large Diaphragm Broadcast Microphone
1 Question, 1 Answer or
Audio-Technica
Part #242-5340
Audio-Technica
Part #242-5340
Model: BP40
With rugged construction and stylish, waveform-inspired design, Audio-Technicas BP40 delivers clear and precise reproduction, ideal for any broadcast application.
  • Large diameter diaphragm with patented floating-edge construction for optimal diaphragm performance
  • Hypercardioid polar pattern improves isolation
  • Humbucking coil prevents electromagnetic interference (EMI)
  • Built-in multistage foam mesh windscreen negates the need for additional pop filters
  • Switchable 100 Hz high-pass filter
  • Optimized capsule placement for commanding vocal presence even at a distance
Your Price: $299.00
MSRP: $349.00
Save $50.00 (14%)
The BP40 broadcast vocal microphone offers a rich, natural, condenser-like sound from a large-diaphragm dynamic design. The diaphragm features patented floating-edge construction that maximizes surface area and optimizes overall performance, while the humbucking voice coil prevents electromagnetic interference (EMI). Audio-Technica optimized the capsule placement to help maintain a commanding vocal presence even at a distance, while the multistage windscreen provides superior internal pop filtering without the need of additional filters. The BP40 broadcast microphone also includes a switchable 100 Hz high-pass filter to provide even more pop protection.
Why Choose a Dynamic Over a Condenser?
Dynamic Mic Characteristics
•    Minimizes room noise – perfect for sonically untreated rooms
•    Smooth audio capture with classic warm broadcast sound
•    Robust construction with no external power requirements
Condenser Mic Characteristics
•    Extremely sensitive – picks up the subtlest sounds in any environment
•    Very articulate audio with a detailed high-frequency capture
•    Requires external power to operate (phantom or battery)
• Element: Dynamic
• Polar Pattern: Hypercardioid
• Low Frequency Roll Off: 100 Hz, 6 dB/octave
• Open Circuit Sensitivity: –48 dB (3.9 mV) re 1V at 1 Pa
• Weight: 632 g (22.3 oz)
• Dimensions: 164.0 mm (6.45") long, 56.0 mm (2.20") diameter
• Frequency response: 50 Hz to 16 kHz
• Accessories Included: AT8483 mounting clamp, 5/8”-27 to 3/8”-16 threaded adapter, Pouch
• Audio-Technica Case Style: R12
BrandAudio-Technica
ModelBP40
Part Number242-5340
UPC4961310130473
Weight2.3
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
