  • Audio-Technica ATH-101USB Single-Sided USH Communication Headset
CLEARANCE Audio-Technica ATH-101USB Single-Sided USH Communication Headset
Audio-Technica
Part #242-5348
Audio-Technica
Part #242-5348
Model: ATH-101USB
The ATH-101USB one-ear USB headset with microphone is ideal for professionals working from home or students enrolled in remote learning.
  • Reversible Design - Wearable on the left or right side by rotating the microphone arm 120 degrees to the left or right
  • USB Type-A output (with USB Type-C™ adapter) for plug-and-play connectivity
  • Built-in noise-cancelling microphone transmits clear audio by suppressing unwanted ambient sounds, pops and other noises
  • Non-isolating earcups ensure natural-sounding conversations and superior breathability for extended, all-day comfort
  • Intuitive remote volume and mute control
  • Headset, controller, plugs, earpads, and windscreen are treated with an antimicrobial agent
CLEARANCE $19.99
MSRP: $27.99
Save $8.00 (29%)
2In Stock
This lightweight, wired headset features a noise-cancelling microphone and one earcup to help keep one ear open to the outside world while still listening in. The reversible design allows users to wear the earcup and mic on their left or right side, depending on listening preference or desk setup. The USB-A output and included USB-C adapter allow for use with computers like PCs and Macs to a wide range of other devices. So, whether you’re looking for a home office headset for conference calls or a solution for students in online school, the ATH-101USB is the best single-ear headset for under $50.
The ATH-101USB one-ear headset was also designed with cleanliness in mind, with the headset, controller, plug, earpads, and windscreen treated with an antimicrobial agent that inhibits bacteria* growth. Although this headset is ideal for professionals and students, it can also be used for gaming and listening to music.
*Certain bacteria only, including E. coli and S. aureus.
• Type: Dynamic
• Driver Diameter: 30mm
• Frequency Repsonse: 20 - 20,000 Hz
• Maximum Input Power: 100 mW
• Weight: Approx. 50 g (1.8 oz), without cable
• Sensitivity: 92 dB
• Impedance: 32 ohms
• Operating Temperature: 5 °C to 40 °C (41 °F to 104 °F)
• Connector: USB Type-A
• Microphone Type: Condenser
• Microphone Sensitivity: -37 dB (1 V/Pa, at 1 kHz)
• Microphone Frequency Response: 200 to 10,000 Hz
• Microphone Polar Pattern: Bidirectional (figure-of-eight)
• System Requirements: Windows 8.1, Windows 10, macOS Catalina, macOS Big Sur; USB2.0 compliant
• Bit Depth: 16 bit
• Sample Rate: 48 kHz
• Power Supply: USB Power (5V DC)
• Cable: 2.0 m (6.6’)
• Accessories Included: USB adapter (USB Type-A to USB Type-C)
BrandAudio-Technica
ModelATH-101USB
Part Number242-5348
UPC4961310156992
Weight0.5
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
