  • Audio-Technica AT6006R Safety Riser for Turntables
NEW Audio-Technica AT6006R Safety Riser for Turntables
Read 1 Review or
Audio-Technica
Part #240-5722
Audio-Technica
Part #240-5722
Model: AT6006R
Read 1 Review or
Tailored for manual turntables, the AT6006R Safety Raiser offers automatic tonearm lift at the conclusion of a record, safeguarding the stylus from potential damage.
  • Lifts tonearm automatically at the end of a record, protecting stylus tip
  • Hydraulic lift with rubber lift bar operates safely and smoothly
  • Can be mounted on a variety of turntables with different tonearm heights
NEW $129.00
Tailored for manual turntables, the AT6006R Safety Raiser offers automatic tonearm lift at the conclusion of a record, safeguarding the stylus from potential damage. Featuring a highly sensitive release antenna and a hydraulic lift with a rubber lift bar, it guarantees secure, smooth, and reliable operation. The raiser includes a height adjustment knob and spacers, facilitating compatibility with a diverse range of turntables with varying tonearm heights.
  • Dimensions: 14mm (0.55") diameter x 27mm (1.06") to 39mm (1.54") height*
  • Lift bar movable width: 3mm (0.12")
  • Weight: Approx. 21g (0.74 oz)
  • Also included: Double-sided tape x4, Spacer x2 (14mm (0.55") diameter x 12mm (0.47") height, 14mm (0.55") diameter x 24mm (0.94") height
*In standby. Height can be adjusted by using the height adjustment knob and included spacers.
BrandAudio-Technica
ModelAT6006R
Part Number240-5722
Weight0.2
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
