Audio-Technica AT2040 Hypercardioid Dynamic MicrophoneBased on the bestselling BP40 broadcast microphone, the AT2040 features a multistage windscreen with nonwoven filter and high-quality foam mesh that provides excellent pop and hiss filtration, without the need for addition pop filters. The integrated shock mount prevents unwanted noise and vibration that can be passed through even the best tripods and boom arms.
The AT2040 is designed with a highly directional, hypercardioid pattern, keeping the recording focused on your voice and your voice alone. This also eliminates unwanted room and background noise - ensuring professional and high-quality recording.
Audio-Technica’s AT2040 includes a pivoting stand mount, 5/8"-27 to 3/8"-16 threaded adapter and a luxury soft protective pouch for easy and safe transportation.
Why Choose a Dynamic Over a Condenser?
Dynamic Mic Characteristics
• Minimizes room noise – perfect for sonically untreated rooms
• Smooth audio capture with classic warm broadcast sound
• Robust construction with no external power requirements
Condenser Mic Characteristics
• Extremely sensitive – picks up the subtlest sounds in any environment
• Very articulate audio with a detailed high-frequency capture
• Requires external power to operate (phantom or battery)
• Element: Dynamic
• Polar Pattern: Hypercardioid
• Open Circuit Sensitivity: -53 dB (2.2mV) (0dB=1 V/Pa, 1kHz)
• Impedance: 600 ohms
• Weight: 615 g (21.7 oz)
• Dimensions: 145.3 mm (5.72") long, 52 mm (2.05") maximum body diameter
• Frequency response: 80 Hz to 16 kHz
• Accessories Included: AT8487 mounting clamp, 5/8”-27 to 3/8”-16 threaded adapter, Pouch
• Audio-Technica Case Style: R13
