Audio-Technica AT-XP3 Dual Moving Magnet Stereo Audiophile DJ Cartridge The AT-XP3 cartridge features a highly-rigid polyphenylene sulfide (PPS)/glass fiber body, has a tracking force of 2 to 4 grams, and offers a powerful output level of 5.5 mV. Its 0.6 mil conical bonded stylus tracks the center of the record groove for reliable performance and excellent fidelity. The cartridge design provides maximum visibility of the stylus tip.
The AT-XP series cartridges provide a high quality sound for vinyl DJ’s. Offering all of the features of a DJ cartridge, but with a Hi-fi sound, the XP series are perfect for the stage and club DJ who prioritizes sound quality.
The durable carbon fiber-reinforced ABS cantilever and nylon wire suspension ensure precise tracking. Providing great tracking and channel separation the AT-XP3 produces a high-fidelity sound which is essential for both DJ and casual listening applications.
The AT-XP3 cartridge is compatible with any XP or VM95 Series replacement stylus, offering a wide choice of options for every budget and application. Compatible with the replacement styli ATN-XP5 and ATN-XP7 for an upgrade of audio fidelity.
• Mounting: 1/2"
• Frequency response: 20 - 18,000 Hz
• Channel separation: 20 dB (1 kHz)
• Output channel balance: 2.0 dB (1 kHz)
• Output voltage: 5.5mV (@ 1 kHz, 5cm/sec)
• Vertical tracking angle: 20 degrees
• Vertical tracking force range: 2 - 4g (standard 3g)
• Stylus shape: Conical
• Stylus size: 0.6mil
• Stylus construction: Bonded round shank
• Cantilever: Carbon reinforced ABS
• Coil impedance: 6.7 kohms (1 kHz)
• Coil inductance: 500 mH (1 kHz)
• Static compliance: 20 x 10 - 6cm / dyne
• Dynamic compliance: 6 x 10 - 6cm / dyne (100 Hz)
• Recommended load impedance: 47 kohms
• Recommended load capacitance: 100-200 pF
• Cartridge weight: 6.2g
• Replacement stylus: ATN-XP3
• Dimensions: 17.2mm H x 17.8 mm W x 28.3mm D
