  • Atlas Sound M2000-SM Surface Mount Sound Masking Transducer with 70V Transformer
Atlas Sound
Part #242-9470
Atlas Sound
Part #242-9470
Model: M2000-SM
The subtle design of the Atlas Sound M2000-SM two-part transducer and transformer provides discrete placement and mounting options, including windows, doors, walls and ducts.
  • Security masking setup for discrete placement
  • Works with many flat surfaces
  • Two part assembly
  • 0.5 to 4 watt transformer taps
Your Price: $100.99
MSRP: $123.99
Save $23.00 (19%)
3In Stock
The Atlas Sound M2000-SM is designed for security masking applications where disruption of planar surfaces is required to prevent laser microphone sensors. Use the M2000-SM on any flat surface, such as windows, doors, walls, ducts or any flat surface. The unit is a two-part assembly that consists of a transducer enclosure and an external transformer interface.
The transducer employs NXT™ exciter technology with a 1" plate mounted coil. The M2000-SM is housed in a discrete, high impact plastic enclosure with 10 ft. insulated lead wire for termination to the external transformer. Quickly install the M2000-SM to almost any flat surface with the pre-installed 3M peel and stick adhesive. Transformer includes simple "keyhole" slots for remote mounting.
Specifications: • Transformer: 70.7V taps at 0.25, 0.5, 1, 2, & 4 watts; Dimensions: 2-3/8" H x 3-1/2" L x 3-1/2" W • Transducer: 1" H x 2-1/2" L x 2-1/2" W; Cable length: 117" (3 m).
Note: The M2000-SM requires a sound masking generator and 70.7V amplifier for operation.
BrandAtlas Sound
ModelM2000-SM
Part Number242-9470
UPC612079185009
Weight1.55
ApplicationFull-Range Exciter
Power Handling (RMS)4 Watts
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
