Model FA138T167 is Atlas Sound's premium 8" coaxial loudspeaker with a factory installed, high efficiency 16 watt 70.7V transformer. The loudspeaker includes a circuit board mounted high-pass/low-pass crossover which produces outstanding sound quality. Model FA138 contains a reinforced polypropylene cone woofer, a custom butyl rubber surround, a 1-1/2" vented Kapton voice coil, a 21 oz. magnet and a 1/2" mylar-dome ferrofluid cooled tweeter for clean and powerful weather-resistant performance. The integral 16 Watt 70.7V transformer features a 40 Hz to 15 kHz frequency responce (+/- 1 dB) with 4, 8 and 16 watt primary taps.
For optimum acoustic and application versatility the Strategy series has been engineered as a system offering both the FA97-8 Series high performance enclosures (.22 ft3) with acoustic batting. The enclosure front-loads the loudspeaker and installs quickly and easily into the ceiling using only a screwdriver to adjust the rotating clamps.
Baffle selection includes a choice of two attractive grilles which are equipped with three serrated studs for hardware-free, push-on installation into Strategy Series enclosures.
Specifications: • Depth: 5-3/4" (14.61 cm) • Diameter: 8-1/4" (20.96 cm) • Shipping weight: 7.42 lbs (3.37 kg) • Frequency response: 75 Hz- 20 kHz (+5 dB) • Power taps: 4, 8, 16 • Speaker type: Coaxial • Dispersion: 110° • Sensitivity: 89.5 B average, 93 dB Peak • UL listed/standard: 1480.
