The TV Box™ combines a recessed dual 110 duplex box with two low voltage brackets for mounting LCD and plasma TVs flush against your wall. Power plugs no longer stick out and inhibit that custom installation that you've seen in commercials. Use the low voltage section for mounting cable connector bulkheads, speaker binding posts, or other datacomm bulkheads. TV Box is 13" wide for mounting between studs, and features non-metallic material with a textured paintable finish. 110 outlet and low voltage devices sold separately.
