  • ART AV DIRECT Multi-Input Audio/Video Direct Box
ART
Part #245-8654
ART
Part #245-8654
Model: AV DIRECT
The AV Direct is the ideal input solution for any application where stereo iPods, laptop computers, consumer DVD players, consumer Hi-Fi equipment or video machines have to be connected to a single XLR microphone level input.
  • Transformer isolated XLR microphone level output
  • 20 to 20,000 Hz frequency response
  • Stereo RCA, 1/8" & 1/4" TRS line level inputs
  • 1/4" & pressure clip speaker level inputs
  • Variable level control
  • Switchable 4.8 kHz high cut filter
  • Ground Lift
Your Price: $85.99
MSRP: $99.99
Save $14.00 (14%)
Out of Stock
The AV Direct is the ideal input solution for any application where stereo iPods, laptop computers, consumer DVD players, consumer HiFi equipment or video machines have to be connected to a single XLR microphone level input. Unlike standard gender-bender cables or DI boxes, the AV Direct can accept virtually any input connection and output level (including amplified speaker outputs) and offers remote level control, ideal for setting the volume of your component at the source, rather than in and AV room, audio closet or installation rack.
The AV Direct has stereo RCA, 1/8" and 1/4" TRS line level inputs, as well as a 1/4" and bare wire pressure clip speaker level inputs. A switchable 4.8 kHz high cut filter, ground lift and variable level control allow the AV Direct to effectively filter out any extraneous unwanted noise while offering variable volume control at source. The speaker level inputs are heavily padded and transformer isolated from the XLR output, allowing amplified speaker level (up to 100 watts @ 8 ohms) to be tapped off, and sent to a microphone level input. A 20 Hz to 20 kHz frequency response ensures the AV Direct will function seamlessly with any high quality audio source.
ARTcessories™ are taking the audio world by storm and quickly becoming a popular brand with musicians, DJs and studio engineers everywhere around the World. Split, combine, mix, power... you name it. On stage, in the studio, in your living room, they’re easy to use and are built to last. For those times when you need a little box to fix a big need or to make more out of a smaller project, ARTcessories™ has you covered. You'll discover a robust line of useful tools which include a complete range of direct boxes, headphone amps, small mixers, mic cable combiner/splitters and much more. ARTcessories™ are designed to deliver affordable solutions for a multitude of audio needs for any size project.
BrandART
ModelAV DIRECT
Part Number245-8654
UPC840402018193
Weight1.1
Active / PassivePassive
Rack MountableNo
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
