  • ACT-15X-120V Amp 600 Watt Full-Range Plate Amplifier - 120V
BUYOUT ACT-15X-120V Amp 600 Watt Full-Range Plate Amplifier - 120V
Factory Buyouts
Part #299-2346
Factory Buyouts
Part #299-2346
Model: ACT-15X-120V AMP
Deliver thundering bass while retaining top end clarity with the B-52 ACT-15X 600W full-range plate amplifier. The compact, Class H amplifier provides the perfect centerpiece for many custom PA speaker build for permanent installs as well mobile entertainers. The amp features a built-in compressor/limiter, 4-stage EQ, a 24 dB/octave subsonic filter at 30 Hz, and thermal and short circuit protection. Product is new old stock (NOS) from the original manufacturer.
  • 600W full range amplifier for custom powered speaker builds
  • Built-in compressor/limiter and 4-stage EQ
  • Ultra-wide frequency response of 40 - 19,000 Hz
  • Perfect centerpiece for custom powered PA speakers for permanent installs and mobile entertainers
The B-52 ACT-15X 600W plate amplifier provides full-range output to power custom built PA speakers. Produce deep, clean low end and detailed, clear high end with the ACT-15X. The amp offers built-in a compressor/limiter, 4-stage EQ, a 24 dB/octave subsonic filter and thermal and short circuit protection. The built-in compression circuitry allows for the ACT-15X to produce high SPLs while minimizing the risk of damage to the amp or the speakers. An ultra-wide frequency response of 40-19,000 Hz will rock any application the amp is used in. With high output, in a compact size, the Class H amplifier will give any PA speaker system build a strong centerpiece to power the most demanding speakers.
Details:
• Class H amplifier with 2-stage power supply
• 1000 watts @ 4 ohms
• Full Range Amplifier – external crossover must be used for components
• Frequency response: 35-19,000 Hz
• Amplifier rated THD: 0.03%
• Amplifier S/N ratio > 100 dB A-weighted
• Amplifier damping factor > 800
• Subsonic Filter: 30 Hz, 24 dB/octave
• Power requirements: 115V/230V 60/50 HZ factory configured
• XLR balanced inputs (Pin 2 = +)
• LR full range output
• Amplifier thermal & short circuit protection
• Signal sensing circuitry with LED indicators
• Oversized convection cooled heatsink for worry-free operation
For over 30 years, B-52 has manufactured Pro Audio gear in California using only high quality components. We recently acquired tons of product from them so they could free up space in their warehouse. This huge buyout of woofers, compression drivers, horns, crossover components, and cabinet hardware is listed here for a fraction of what you would normally pay. Many drivers in this factory buyout are New Old Stock (NOS) from famous brands and would be considered vintage. Like the B-52 bomber, this factory buyout travels the globe and includes drivers manufactured by famous brands around the world in places like the UK, USA, Denmark, and Brazil. This is a one-time buyout opportunity so quantities are limited.
Specifications: • Amplifier type: Class H with 2-stage power supply • Power output: 600W @ 8 ohms • Max SPL: 130 dB • Frequency response: 40 - 19,000 Hz • Max power requirements: 120 VAC, 5A • Rated THD: 0.03% • DSP: Built-in compressor/limiter, 4-stage EQ • S/N ratio: 100 dB A-weighted • Subsonic filter: 24 dB/octave @ 30 Hz • Inputs: 1 x XLR • Outputs: 1 x XLR • Thermal and short circuit protection • Cutout dimensions: 18.75" x 9.5" • Dimensions: 20.5" x 11" x 4".
BrandFactory Buyouts
ModelACT-15X-120V AMP
Part Number299-2346
UPC848864052557
Weight13.9
MONSTER DEAL
OF THE WEEK
$29.98 EACH
SAVE 25%
Talent SB16-32 Stage Boss 32.5 ft. 16/3 Multi-Outlet Commercial Grade Extension Cord with 7 AC Sockets
