  • 12 VDC 2000mA Regulated Switching AC Adapter 2.1 x 5.5mm Plug Center Positive (+)
BUYOUT 12 VDC 2000mA Regulated Switching AC Adapter 2.1 x 5.5mm Plug Center Positive (+)
Part #129-122
Part #129-122
This regulated 12 VDC 2A switching power supply is ideal for replacing lost or damaged power supplies from your electronic devices or as a foundation for new projects.
  • Common 2.1 mm x 5.5 mm x 9 mm plug
  • UL listed, and FCC approved for safety
  • Efficient and reliable switching power supply
BUYOUT $4.98
MSRP: $14.99
Save $10.01 (67%)
Order in the next 5 hr 43 min to ship today. Details
2381In Stock
Switching power supplies are reliable, compact, and efficient. This regulated 12 volt DC power supply provides ample current to run many popular 12V devices. Use it to replace a lost or damaged power supply for AV equipment, office devices, battery chargers, and other electronic components. UL listed and FCC approved.
Specifications: • Power output: 12 VDC 2A • Power input: 100~240 VAC, 50/60 Hz. Output connector: 2.1 mm x 5.5 mm x 11 mm, center positive • Cable length: 5 ft. • Adapter dimensions: 1.8" W x 2.75" H x 1.5" D without AC prongs.
Part Number129-122
UPC848864046068
Weight0.3
Center/Tip PolarityCenter Positive
Current Capacity2000mA
DC Output Voltage12V
Input Voltage100~240 VAC
Plug Size2.1 x 5.5 mm
    MONSTER DEAL
    OF THE WEEK
    $14.98 EACH
    SAVE 25%
    Dayton Audio Boost Mini Portable Bluetooth Speaker Black
